The 50% for the UL taps refers to the turns ratio, but the impedance is proportional to turns ratio squared, so 12k x 0.5 x 0.5 gives 3k.
Excellent point. I'm looking at doing a push-pull el34 and thinking a of using the UL taps on a transformer to get into the ball park for 4 el34 tubes. I'm just confusing myself I think by thinking like this.
At half the winding you will get a quarter the impedance match and a quarter the inductance, so the frequency balance will be the same. You will get half the winding resistance, so a small loss of efficiency.
An extra issue is heating. You might want to run with twice the DC or signal current, but this will give you twice the heating so you may need to derate the transformer.
- Tubes / Valves
- Using UL taps instead of the anode taps to alter inpedence
