Valve HT power supply common-mode noise - diyAudio
Old 6th July 2014, 11:15 AM   #1
Default Valve HT power supply common-mode noise
Hi guys, I am having trouble deciding whether or not to use a toroidal or an IE transformer for my HT supply.
Do you think that noises(also known as common mode noise) that slip through from the AC main to the HT supply via the interwinding capacitance of the power transformers would induced unwanted distortions(i.e. hums)?
I do know that due to the capacitive coupling between the heater filament and the cathode, the heater power transformers must have a low interwinding capacitance + shield + bobbin or IE transformers to stop main AC noises from getting through. However, for the HT(plate/anode supply) in a pull-push configuration, I believed that common mode signals are canceled, thus says a toroid power transformer could be used. Even though toroid would let more AC main noise through because of their higher interwinding capacitance.
Old 6th July 2014, 01:37 PM   #2
disco is offline disco  Netherlands
disco's Avatar
My 2ct is that some builders go to extremes for that ultra low noise "black background" experience, a concept that can't be had without inclusion of all parts. If you are satisfied with "a reasonable result without much hassle" you might get away without attention to CM noise because there are bigger issues involved in a power stage.
The regulation of the power transformer is an overlooked property. On the other hand a bulky 200VA unit is overkill for a pre amplifier, where the smaller radiation distance of a toroid in combination with CM filtering might be beneficial.
I never obtained an answer to the question I posed whether or not it will be harmful for AF signal integrity when CM noise passes or oscillation occurs, way above AF.
jaap
Old 6th July 2014, 02:29 PM   #3
DF96 is offline DF96  England
I'm not sure if you are asking about noise, hum or distortion: three different phenomena.
My understanding is that toroids can let through more differential-mode noise due to better HF magnetic coupling between windings.
Old 6th July 2014, 03:10 PM   #4
kevinkr's Avatar
They generally have lower leakage inductance than EI types. In this case the EI has an advantage, however this can be addressed quite effectively with a combined CM/DIFF mode choke or good quality line filter on the input side of the transformer.
The other thing to bear in mind with the toroid is you quickly loose the benefit of its good magnetic containment if you allow it to saturate during any part of the rectification cycle. Over sizing here is good.
I use a mix of both. Recently Antec has started offering transformers with electro-static shields which helps with HF noise.
"Extraordinary claims require extraordinary evidence." - Carl Sagan
Old 6th July 2014, 07:21 PM   #5
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
There is little point wringing your hands over common-mode noise unless the rest of the design is already exceptionally well optimised. Is you amplifier exceptionally well optimised?
Old 6th July 2014, 11:03 PM   #6
kevinkr's Avatar
This of course is an excellent point. In practice it has caused me little or no trouble. Unintended loops have always been the bane of my my existence.
Old 7th July 2014, 03:35 AM   #7
AJT is offline AJT  Philippines
AJT's Avatar
oh but i have seen a local build with such sized traffo and a 5U4 tube rect, feeding a circuit that only required a few mA at just about 120volts plate B+....
laws of physics have been casually ignored....
Old 7th July 2014, 08:09 AM   #8
Seem like no-one here have much of an issue with common-mode noise getting through.
But wouldn't everyone here agreed that common-mode noise is canceled in a pull-push configuration? The reason is because common mode signal is of the same magnitude, polarity and common to both valves. Thus it get subtract from one another in the output pull-push transformer?
If what I stated is true, then wouldn't everyone agreed that a toroidal power transformer is a perfectly acceptable(even though it let more CM noise through) replacement for an EI core transformer in the HT supply?
The reason i asked this question is because of the popularity of EI core power transformer in valve amp, while toroidal is some what rare.
Old 7th July 2014, 09:13 AM   #9
disco's Avatar
Not quite, it has meaning if everything else is top notch.
CM signal is cancelled in a differential amplifier: it amplifies differences in grid signals and ignores signal common to both inputs. A push pull amplifier does not have this property.
jaap
Old 7th July 2014, 09:47 AM   #10
Yes it does. A perfect PP output stage will cancel any supply rail noise, although there would still be supply rail intermodulation. Big snag: no PP output is perfect.
In my early days of learning electronics I would often obsess over unimportant details while completely ignoring much more important circuit problems. Part of the art of electronics is knowing which things to worry about, and which things to ignore (perhaps after doing a back-of-envelope estimate of their likely magnitude).
Common mode feedback dirkwright Tubes / Valves 28 9th March 2012 12:26 AM
Differential amplifiers ...noise, common mode etc. peskywinnets Analogue Source 17 24th February 2011 11:45 AM
differential design, common mode noise rejection Sebastiaan Solid State 0 17th April 2006 08:16 PM
Power Supply Common Wire... EchoWars Solid State 4 4th December 2003 12:01 PM
Using common mode chokes in filament supply. G Tubes / Valves 8 9th December 2002 03:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
