Help me to choose tube "1 no ring" "2 has ring" - diyAudio
Old 5th July 2014, 01:12 PM   #1
sjp7mau is offline sjp7mau  Viet Nam
Default Help me to choose tube "1 no ring" "2 has ring"
tube 1 or tube 2 better?
Old 5th July 2014, 02:26 PM   #2
maton00 is offline maton00  Mexico
maton00's Avatar
Send a message via MSN to maton00
Some purists would select the no ring or no getter tube, simply because its old or expensive, the right tubes are better because its rugged construction, they have better suports and have getters so that can absorb stray gas particles that can be emited by the valve itself or by atmosferic gas penetrating the glass, so they will last longer and they are also newer.
So what would you choose?
Old 5th July 2014, 02:59 PM   #3
Palustris's Avatar
Which sounds better to you?
Old 5th July 2014, 03:03 PM   #4
SY's Avatar
No way to tell visually.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 5th July 2014, 03:30 PM   #5
Hi.
I wondering The "Brimar 5Z4G" tube and "5Y3GT" tube is replace to a 5Y3WGTA? Then, i wondering about voltage if choose 5Z4G, so i want upgrade 5Y3WGTA Sylvania by 5Y3GT Fisher.
Price Tube 1 = Price tube 2, and i wondering choose tube 1 or tube 2
Old 5th July 2014, 03:35 PM   #6
dady is offline dady  Balearic Islands
dady's Avatar
Send a message via MSN to dady Send a message via Skype™ to dady
I choose With Ring.
Are Rectifiers sounding or rectifying?
Esteban Bikić
Old 5th July 2014, 06:56 PM   #7
DF96 is offline DF96  England
A rectifier without a getter might not work too well. However, lack of a visible getter does not necessarily mean 'no getter'. It may be faint, due to age or a slow leak, or it may be hidden in the base.
The ubiquitous 1/2"...um....3/4"...er 1" ?? polycarbonate "dome" tweeter River757 Multi-Way 16 8th July 2013 12:45 AM
3-way with big (10") woofer and monitor (6.5"+1") on top like "Tarkus" proxii Multi-Way 16 30th October 2012 12:43 PM
Ring-Modulated Sound from Vintage 12" Magnavox Driver SlunkBoy Full Range 1 2nd March 2011 08:44 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Any recommendation on using Vifa 1" ring radiator (XT25TG30-04) deltavektor Multi-Way 3 25th October 2008 09:10 AM
Copyright 1999-2017 diyAudio
