help please - modify phono corrector
Old 28th June 2014, 05:11 PM   #1
Vincin is offline Vincin  Viet Nam
Default help please - modify phono corrector
What do I change in the attached schematic to use the E80CC valve, instead of the 6072A.
Nothing wrong with the 6072a valve, the circuit sounds very good using this valve. I just have a bunch of NOS E80CC and want to put them to use.
thanks a million.
Old 28th June 2014, 05:19 PM   #2
DF96 is offline DF96  England
Just recalculate most of the component values, to take account of the different valve characteristics (e.g. anode impedance, quiescent current). First, reverse engineer the circuit to determine exactly what the designer had in mind. Then redesign it for a different valve.
Alternatively, find a similar circuit already designed for 6072 or 12AY7.
Old 28th June 2014, 05:29 PM   #3
Sir, I wish I could do what you said: "reverse engineering". Then I would have the opportunity to enjoy this hobby 10 times more. The matter of fact is that I do not even understand how the first stage cascode circuit works.
all I know is the RC EQ networks need to be changed to compensate for the different valve.
so if you could spare 5 minutes to punch some numbers and advise me exactly what I need to do, I would appreciate that very much.
Old 28th June 2014, 05:39 PM   #4
Sorry, it would take a lot more than 5 minutes. Hours, at the very least.
If you can find a circuit designed for E80CC then use it. If not, it may be that E80CC is not a suitable valve for a phono preamp.
Old 28th June 2014, 07:15 PM   #5
kevinkr's Avatar
E80CC has a mu of 27 and a transconductance of 2700uhmos vs a mu of 40 and a transconductance of 1700 for the 12AY7A. The cascode section would give you more gain, the second stage significantly less.
You can adjust the value of R8 so that the plate current with the E80CC is approximately 1.2mA.
You can adjust R19 so that the plate current is approximately 1.3mA.
Finally you may need to adjust the value of R17 - this should be sufficient for decent RIAA conformance. Do you have any means of measuring the frequency response?
The gain in the first stage will be higher, the second lower. I'd just swap the tube and do some voltage measurements to see whether resistor values listed need to be changed.
I don't have models for this tube so I can't simulate this circuit, but it is quite similar to one of my more recent designs and should not be too difficult to tweak.
Are you building from scratch or converting a 12AY7 based pre-amplifier you already own? The reason I ask is if you are building I would suggest somewhat higher operating currents in each stage for better linearity, and better drive capability in the second stage.
Without good models or samples it is very difficult to advise what the specific values need to be, but with the exception of R17 none of the other values are critical. When I design a new phono stage I model it in spice, build a prototype and determine how close to my design goals the design comes and then modify it on the bench until it achieves something close to the targeted performance.
I have both quite a lot of test equipment and experience designing phono stages, making random tube changes without a clear expectation of performance goals and without the means of extensively testing the changes is not an ideal recipe for achieving good performance. If you are willing to invest the money for the required test gear and the time to learn it can be a worthwhile process.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 28th June 2014, 07:57 PM   #6
Ketje is offline Ketje  Belgium
Ketje's Avatar
Curious values has those resistors.According to the 6072 data from GE ,R8 results in a higher current and less voltage on the top plate.Still fuctionig but giving less headroom.
Putting in a E80CC (practicaly the same as a ECC40) make the resistors allmost right.
Beware , the E80CC draws much more heater current.
Second stage ,data says R19 not 1k2 but 1k8 and for a E80CC 3k9 to get the indicated current (voltage on R15.
Mona
Old 29th June 2014, 10:35 AM   #7
Kevin,
thanks. The circuit I posted is of Audio Note UK, same as in most of their phono preamp. I built their kit phono stage years ago.
I plugged the E80CC in there this morning, sound is ok. Up the second stage current by reducing the cathode resistor Rk from 1.2K to 820Ohm, and down anode resistor Ra from 10K to 68K, new Ia = 2.45ma, as you have suggested "higher operating" point, the sound is even better. The better drive and lower impedence must have helped a bit.
I guess this will do it. Im not that much of a golden ear who can pick out un-even frequency response so I will pass the steps to make it perfect.
One question remained though: that 270K resistor, how do I change this given the 1st stage lower driving impendence of the new valve (E80CC vs 6072/12AY7).
thank you very much
Old 29th June 2014, 10:54 AM   #8
Ketje's Avatar
The output impedance of a cascode circuit is very high,somewhat like a penthode,several 100-th Kohm.So the output is almost =R7. If you didn't change that the 270k is ok.
Mona
Old 29th June 2014, 11:24 AM   #9
great, no further change.
on a different technical aspect of the same phono circuit, I have a question on suitable output capacitor value. The phono output is driving a Silk TVC used as volume control at the input of an active linestage. Yes I have read that the valve phono stage is not suitable to drive TVC ie: high impendence, LC resonance & damping etc.. I wish I understand all that but I simply clueless.... I use the TVC because it sounds so much better than the resistor volume control type, and Im able to eliminate the ground loop at the input of the linestage.
Silk state on their website their TVC has more than 1000H primary inductance.
so in the ballpark estimate what output cap value for the phono stage should i use? my vinyl rig is tuned to a resonance frequency of 7-8hz I think.
at the moment I use 0.47uf, there is a bit bass reinforcement, which is quite nice actually.
Old 29th June 2014, 04:29 PM   #10
kevinkr's Avatar
You may want to try a range of values to suit the LF rise you want (or not) I would try a 1uF and see where that takes you. Much larger is probably not required..
help please - modify phono correctorHide this!Advertise here!
Power Factor Corrector Inductors Mostech Power Supplies 0 8th February 2011 08:58 AM
Kulish Corrector applications GEirin Solid State 12 30th December 2007 07:52 PM
Phono preamp- how to modify to get deeper LF? MaciekP Tubes / Valves 4 15th March 2004 11:13 PM
help me modify my phono amp.(Please) sleepy Analogue Source 5 28th February 2003 01:01 PM
