#21 |
Well I'm certainly no 300B snob - especially given that three weeks ago I didn't know any such beast exists. All I knew was EL34s and 6L6s and that was from my guitar days.
I selected the 300Bs because so many sites seem to support them and there is so much being done with them - so I thought for a new boy I would find more support. Perhaps I'll post another thread on what valves - god help me.
Audio |
#22 |
I take the opportunity to ask you, tube masters, about the trannies.
Lately I've found that I can build my own transformers, as I have the magnetic sheet, the enameled wire and some books on trannie design (standard ones). Could someone point out some tips about features required for this kind of output transformers? any web? Thanks.
What is beyond the speaker? |
#23 |
While I would not recommend winding your own transformers, considering safety regulations and all that, I do believe Google should be able to turn up a few references on the subject.
If not, give me a private message, and I'll see if I can dig up a few book references that I had lying about a little while ago. |
#24 | |
I have heard support for AE too, they have the best prices I've seen for Amorphous cores, would love to try them in a 300b design! Thanks Raja |
#25 | |
Actually building a published design isn't that hard and any questions on faults or difficulties in construction would probably be answered by the same bunch of people here irrespective of the design as most are common things such as hum or grounding. Besides, suppose you chose to build a JE or an F&B 300B SE, everyone buiilds theirs differently so unless you copy someone else's implementation, you're on your own to an extent anyway. I'd suggest as a beginner tube project, you don't build a 300B. Quality tubes are too expensive. |
#26 |
Was wondering how the electraprints stack up to some other brands mentioned?
#27 |
So can anyone with a bit of experience across multiple transformer sets rank them in terms of perceived quality?
Should the Chokes be from the same manufacturer? Thanks Again Ralf
Audio |
#28 | ||
diyAudio Senior Member
Either way they do not have to be from the same manufacturer at all. Why should they, after all.... Quote:
Frank |
#29 | |
They may be better than the B&O transformers I use now ![]() Best regards, Mikkel C. Simonsen |
#30 | |
It's from an old German book and a German magazine. I have never wound any myself, but I guess the formulas should work. At least the power transformer formulas from the same book work nicely... Best regards, Mikkel C. Simonsen |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Help identifying a pair of output transformers and power transformers | mjk130 | Parts | 3 | 30th January 2009 10:44 AM |
| 2a3 output transformers.... | button_fly | Tubes / Valves | 3 | 10th October 2007 02:05 PM |
| Output Transformers | eduardio | Tubes / Valves | 2 | 13th May 2005 02:42 PM |
| Using output transformers on Zen Amp? | G | Pass Labs | 14 | 5th November 2004 11:54 PM |
