2A3 Output Transformer
Old 11th January 2004, 12:05 PM   #1
TunaFish is offline TunaFish  Hong Kong
Default 2A3 Output Transformer
Hi all expert,
For a SE 2A3 (output 3.5W), what size of the output transformer is big enough?
1. 10W SE
2. 20W SE
3. 30W SE
Is bigger = better? Since the output is only 3.5 W, does 10W SE output transformer enough?
Thank you for your help.
Tuna Fish
Old 11th January 2004, 12:32 PM   #2
mcs is offline mcs  Denmark
Yes, a 10W transformer is enough. I use a 4-5W transformer in my amp (came from a Beovision 3400), and that works very well.
You should worry more about frequency response, primary inductance etc. The Watt rating does not matter. The larger transformers may be better, but not always.
Best regards,
Mikkel C. Simonsen
Old 11th January 2004, 06:43 PM   #3
If I got the transformer on hand, how to check the frequency respond?
What kind of equipments I need?
Old 11th January 2004, 09:08 PM   #4
To test a transformer you would need at least an audio oscillator, a scope and a VTVM.
But I am not sure how to do the actual testing, because for the test results to be correct you would have to simulate the actual circuit the transformer is intended for.
That means the signal source should have the same impedance as the tube. You should also pass the correct amount of DC through the primary.
For some tests of PP transformers look here: http://www.one-electron.com/Trans_Tests.html
Best regards,
Mikkel C. Simonsen
2A3 Output TransformerHide this!Advertise here!
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
toroid Transformer as output Transformer for tube preamp? tone Tubes / Valves 15 2nd February 2003 04:36 AM
