Newbie - Is this a good amp?
Old 11th January 2004, 10:40 AM   #1
Mas Penk is offline Mas Penk  Indonesia
Default Newbie - Is this a good amp?
I wanna make bigger amp (20-50 watt) and this amp from Vacuum State :
http://www.vacuumstate.com/images/PP-1C.gif
http://www.vacuumstate.com/images/PP-1C_ps.gif
Does any have built this amp? Can replace El34 with SV6550C?
or may be suggestion about building another good sounding PP amp specially using 6550...
I wanna build this because it has no feedback (which alot of people say it has a bad effect) and it uses plate load on driver....
Help me please...
Mas Penk
Old 11th January 2004, 11:53 AM   #2
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
I have not had good luck with the SV6550C tubes due to premature tube failure. For that reason, I have converted my power amplifier to Sovtek KT88 tubes. I couldn't be happier.
Inverse feedback in push-pull amplifiers is almost always necessary to reduce crossover (notch) distortion and to reduce the output impedance of the amplifier.
Frank
Old 11th January 2004, 02:17 PM   #3
So what do you think about that amps....?
Mas Penk
Newbie - Is this a good amp?Hide this!Advertise here!
Good Amp Kit 4 Newbie??? Mindcrime Vendor's Bazaar 0 19th April 2007 01:20 AM
Good SET for newbie Jimmy_The_Clown Tubes / Valves 3 5th November 2004 06:44 AM
Good Amp for Newbie PaulHilgeman Solid State 8 4th July 2003 01:41 AM
is this amp good for newbie project?? behnkem Solid State 5 13th March 2003 02:42 AM
Good bookshelf speaker project for newbie dlancep Multi-Way 1 10th January 2002 07:26 AM
