Hi I've finished building the aikido 12vac pre amp from John broskie and I've been having a few issues getting it to run properly. Sometimes it work flawlessly but every so often when I turn it on resistor 2 fries. I've checked all the components and there all the correct values and it the right position. also When its working sometimes one of the channels doesn't work or its very quite. I tried rotating the tubes around but it just fries a different resistor usually resistor 11. I'm using 1/5 watt metal film resistors. Any help would be great. Thanks
Hi im using jj electronic e88cc tubes. I've included the schematics and recommended part values below. thanks for your help. Allister
