cs300x
Hello All,
I would like to build this amp utilizing ecl86 instead of the the 12ax7 and el84 the design calls for originally. Based on all I was find on the net should be no problem although the power will be lower then the original.
What do you think?
In addition, I am considering removing the NF electrolytic cap and re arraigning the bass boost filters in such a way that it will always be in the loop and the selector will decide which network is shorted - thus taken out of the loop WITHOUT disconnecting the loop.
This way, the NF loop is never cut off and reconnected only the resistance and capacitance in the loop changes with the selector.
What do you think?
Thanks,
Glass_painter
Hello All,
What do you think?
What do you think?
Thanks,
Glass_painter
- Tubes / Valves
- Leben CS300x feedback loop cap
