Grounding Qustion?
Grounding Qustion?
Old 8th June 2014, 06:58 PM   #1
nikon f is offline nikon f  United States
Default Grounding Qustion?
I was given a pair of Ampex 6973 mono block amplifiers. Should I install a three prong AC cord that grounds off the chassis or stick with a two prong cord?
Old 8th June 2014, 07:09 PM   #2
okcrum is offline okcrum  United States
Install three conductor power cables and ground to the chassis. If there are caps to ground on the AC primary, remove or replace with AC safe caps (they fail open).
Old 8th June 2014, 08:13 PM   #3
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
Always best to have the chassis at ground potential. If you get hum issues, use a 10R 2W5 resistor (that has a 1nF cap and back to back 1N5401 diodes across it) in series with the Earth conductor in the chassis end, that will ensure coupling for safety to ground but allow for earth loops.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 8th June 2014, 09:02 PM   #4
famousmockingbird is online now famousmockingbird  United States
Would those 3A diodes be enough for fault currents? Maybe I went overkill but I think I used a 30A bridge
Grounding Qustion?Hide this!Advertise here!
newbie qustion sharon1 Headphone Systems 3 29th July 2013 08:41 PM
Noobish qustion - Can you use a doorbell transformer for..... JZatopa Parts 2 4th April 2011 01:49 PM
aikido phono schematic qustion wicked1 Tubes / Valves 0 2nd October 2009 04:47 PM
qustion about amps Bazukaz Class D 0 29th December 2005 11:43 PM
qustion on tube grade wiring ThSpeakerDude88 Tubes / Valves 10 4th October 2005 08:27 PM
