Scope pattern - diyAudio
Old 6th June 2014, 06:13 AM   #1
mr2racer's Avatar
Default Scope pattern
Hey Anyone,
I built Pete Millet's uniamp using 2A3 outputs. The voltages are all good but it is really distorted? My scope is a goner so I borrowed an old Simpson . The Simpson uses banana plugs for the inputs and I don't have any probes or leads for it so I just used speaker wire from the output. And when taking a digital picture of the scope you can't see the pattern at all. Maybe it will work better in daylight? Anyway, I drew a crude sketch of the pattern at the output and have never seen this pattern before. Does anyone have any ideas? I plan to make up a set of leads tomorrow to find out where the distortion is occuring but in the mean time any ideas?
Artificial intelligence is no match for natural stupidity- Red Green
Old 6th June 2014, 09:56 AM   #2
JonSnell Electronic's Avatar
Is the feedback, if any, the correct phase? What signal are you feeding it, looks like square wave and what frequency?
Looks like a partially integrated square wave.
Support for PMC DS-001, (Hypex) UcD400,Valve Equipment and designs both new and old. www.jonsnell.co.uk
Old 6th June 2014, 11:51 AM   #3
Matt BH is offline Matt BH  United Kingdom
What cathode resistor value are you using for your 2A3's?
Cheers
Matt
Old 6th June 2014, 01:05 PM   #4
DF96 is offline DF96  England
Looks like bass boost, combined with a little overshoot.
Old 6th June 2014, 02:52 PM   #5
mr2racer's Avatar
Thanks guys, there is no feedback. The signal is a square wave at 1k. cathode resistor is a ten ohm, the amp uses fixed bias. The outputs are set at 40ma. And yes the low frequencies seem to be more distrotred.
Old 6th June 2014, 04:25 PM   #6
Ah ok, fixed bias and square wave. It just looked like way under biased and cutting off one valve either side with the notches which I guess are around zero crossing.
Anyway a sine wave would tell more for now.
Cheers
Matt.
Old 7th June 2014, 04:00 AM   #7
hooman is offline hooman  Iran
hooman's Avatar
can check sine wave ?
Old 9th June 2014, 05:40 AM   #8
mr2racer's Avatar
I checked the amp with a sine wave and found it to be clipping the bottom of the wave form. Then I traced it to a problem with the way I wired the input transformer. Thanks for the help!
Kevin
Old 9th June 2014, 09:26 AM   #9
disco is offline disco  Netherlands
disco's Avatar
Yep,, thought so
It's a classic 'too low bandwith' sign, according to Valley & Wallman.
jaap
Noise pattern kzeprf22 Solid State 1 1st February 2013 01:12 PM
USB Scope - Real scope and not too expensive Algar_emi Equipment & Tools 11 17th March 2010 12:40 AM
Pattern around tweeter... Godzilla Full Range 6 9th December 2008 01:17 PM
Great deal on Digital scope. Is this enough scope? hifimaker Pass Labs 1 1st May 2007 10:59 PM
Copyright 1999-2017 diyAudio
