I am trying to put some price lists together on an tube amp I want to build up, and have a technical question for you. I understand alot of theroy which says this should work, but i want to make sure in the real world it would too.
I need 350V for a power supply I am going to be building up, today, for $10, i obtained a very heavy transformer which steps down voltage by labeled use. But what if I ran the transformer "backwards", in other words, where normally the transformer is designed to take high voltage on a line at say 380V and can put out 120V once stepped down, could I not plug line AC into the transforer at the 120V tap and then expect to get 380V out? I mean in theory is just two coils, what works one way should work the other right? Since I am a poor college student, can I at least try this method, or am I likely to run into some adverse reaction and melt the sucker? Incase its of any use, its a Acme Transformer, Type No TA-2-32669 and is labeled as an "Industrial Control Transformer" Thanks Guys B
Stewie: You there, fetch me the wall street journal. You two! Fight to the death! |
#2 |
Cant' see why not, if it is rated for 380V...
Keep in mind that 380V rectified in a bridge is likely to give you around 450V! |
#3 |
Theorectically only the primary is required to meet safety insulation standards for connection to the mains power supply.
In practise I can't see any real problems using it in reverse. sreten.
| Quick transformer question | Brit01 | Tubes / Valves | 5 | 23rd July 2009 07:26 PM |
| Another quick transformer question | Hiwatt25 | Chip Amps | 6 | 8th February 2008 10:56 AM |
| Quick Transformer Question | krzanik | Tubes / Valves | 2 | 17th May 2007 09:15 PM |
| Quick Output Transformer Question | dsavitsk | Tubes / Valves | 5 | 20th April 2006 07:08 AM |
| Quick LM4780 Transformer Question | dfdye | Chip Amps | 4 | 16th December 2005 07:46 PM |
