Dear all high hand,
I have a kit for CS43122 but I would like to modify the analog output stage to use tube output lilke the picture shown. Unfortuately, the CS43122 output is balanced with Vout+ and Vout-. How should i readjust the ciucuit accordingly? |
#2 |
Hi
As the output of the DAC is balanced and needs to have at least a 12dB/oct. low-pass I propose you experiment with a dual triode ( one half for the phase and one for the antiphase output ) followed by another dual triode that is charged with an output-transformer. ( balanced ) Not a power output transformer ! Andre |
#3 |
Did a quick drawing of my idea.
Sorry for the clumsy quality, my CAD had no symbols of valves so I used OO-draw. Andre |
#4 |
Say, do you want a balanced output from the tube stage or a single ended output?
#5 |
A single ended output as I have RCA only!
#6 |
Thanks nonik for your schematics very much.
#7 |
Just use a transformer. No modification to the circuit will be required.
#8 |
I agree that, if the output voltage is sufficient, a good audio transformer would be easiest. However, if you really want a tube output stage and if you don't mind cathode followers, the circuit on this link will convert from balanced to single ended:
Broske Cathode Follower If you need gain, it should be easy to add a tube gain stage. |
#9 |
The idea of just using a transformer on the
output is very attractive, as fewer parts could only improve quality. However, every DAC needs a low-pass on its output even if they use digital brick-wall filters in the DAC. You cannot rely on the roll-off of the transformer as, a quality audio transformer could go as far as 100kHz. ( but i assume that is known by valve enthausiastics ) however the low-pass needed should match the fs used in your DAC. So you need to add some passive filtering wich has to be designed very carefull, incorporating the specs of the transformer. Remember that the complex load of such combination together with any load "on the other end of the output-cable" will directly charge the DAC-output. So I would prefer to use some buffer. A valve as ackcheng asked for. btw the circuit i proposed is for one channel and the output does not necessarily be balanced. just tie one end to GND ! Andre |
#10 |
The Broskie Cathode Follower is an exceptional performer.
Moreover, with a balanced supply the output condenser can be avoided but, in this case, a bias adj. resistor will be required. Federico |
| Help with PSU for tube DAC output stage | luvdunhill | Tubes / Valves | 1 | 6th May 2008 09:10 AM |
| Tube Output Stage | Mighty Mouse | Tubes / Valves | 3 | 24th August 2004 08:08 PM |
| Tube output stage for DAC | ackcheng | Digital Source | 0 | 9th January 2004 05:03 PM |
| dac tube output stage..pls help. | tone | Tubes / Valves | 80 | 25th March 2003 06:13 PM |
| need help on tube output stage.. | tone | Digital Source | 2 | 19th March 2003 04:52 PM |
