James or Silk for EL36SE? - diyAudio
Old 31st May 2014, 05:21 PM   #1
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
Default James or Silk for EL36SE?
Allthow I at the moment don`t have cash to buy the them I would like you oppinion.
I am building an SE amp with EL36 and I`ve been reading allot about SE transformer in diyaudio and Ive decided to go with either James or silk..
And I would like the abbillity to shiftbetween triod and UL.
So its either Silk S-305
or James JS-6113HS
or possibly James JS-6123HS if it makes things better..
I will be running EL 36 at about 50mA.
Regards ke
Old 31st August 2014, 05:50 PM   #2
Send a message via Skype™ to valmig21
HI,JS-6123S and EL36 with 350V/50ma are 6wats crystal saund.If you use 6S45P with ihterstage transformer...it,s great!
Old 31st August 2014, 06:51 PM   #3
Location: Near Eindhoven, the sanctum of the pentode. and among that other things.
Send a message via Skype™ to v4lve lover
If you want a more elaborate data sheet on the EL36, the E235L is exactly the same tube without the top cap.
you could try screen drive, lineairity ought to be good judging from the curves published in the E235L datasheet.
Old 31st August 2014, 07:30 PM   #4
Both long life?
Old 31st August 2014, 11:25 PM   #5
EL36's have published curves for screen grid drive, so that would seem one way to explore its nature in a somewhat unusual way? The other feature which stands out for me is that Ia curves are published showing operation at some pretty chunky currents, somehow seems a shame to only use 50mA - I know max Ik spec is only 200mA or so (IIRC), but I've always felt that might well be a 'conditions' rating for its intended tv line stage use - not that I have explored higher current operation personally.....the high heater current implies a hefty cathode I think.
Dunno, not sure I would just do a 50mA/pentode/triode SE with an EL36, it's such a curious valve, might offer up more in some alternate modes?
Silk Transformers wicked1 Tubes / Valves 36 30th August 2013 02:13 AM
SE and PP James and Silk Transformers for Sale ppereira Swap Meet 3 29th November 2011 07:33 PM
SILK 4" out to 20k RAW Multi-Way 18 30th April 2004 05:41 AM
DIY Silk screen maylar Solid State 3 20th March 2004 05:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
