SE45 schematic monoblock to stereo help - diyAudio
Old 28th May 2014, 03:44 PM   #1
Default SE45 schematic monoblock to stereo help
Having looked at so many schematics and talking with folks here i have come to the conclusion to try this circuit. I have not done point to point before but am very confident soldering (having built many patch bays and soldered on PCB's).
What I need help with is to add in a potentiometer and make this thing stereo instead of monoblock. I know its a large thing to ask but you real tube guys could probably show me where to run things.
Old 28th May 2014, 05:39 PM   #2
you have forgotten to add this link: www.positive-feedback.com/issue1/single.htm
Now people can see what you are talking about.
R1 is 249K, so a 250K stereo pot will do it. It works with the mono psu. But you can add a RC for each channel, after C2 for better stereo separation. You need real high eff. speakers for this 1.6 watt amp.
Johann
Old 28th May 2014, 06:13 PM   #3
Thanks for a quick reply. I have 97db/m efficient speakers that my Decware Zen drives nicely with only 1.8W at max.
The RC values I wouldn't be able to guess at.
Wouldn't the power tranny need to be twice as powerful?
I'm a picture guy so I need to see how the power supply will look drawn in stereo from the rectifier onward.
I will use a 5R4 for rectification.
Any comments about the CCS? Chip options?
Old 29th May 2014, 10:38 AM   #4
I'll send you a pm.
Old 29th May 2014, 10:44 AM   #5
nl3prc is offline nl3prc  Netherlands
nl3prc's Avatar
I don't see in the schematic the tube's that are used.
I the past i came up with something like this.
For ECL82 3W amp and the ECC83 and EL84 for the 6W amp
Tube_power_amp_3w_ECL82-J.zip
Tube_power_amp_6w_EL84-c.zip
Old 29th May 2014, 02:10 PM   #6
debk is offline debk  United States
debk's Avatar
The tubes are a 5965 and a 45
There is a parts list on the next page of that issue of Valve, October 1997
Old 30th May 2014, 10:57 AM   #7
nl3prc's Avatar
Johann
Problem here is that i can't open the link you posted
Old 30th May 2014, 01:37 PM   #8
sorry, it does'nt open. Add http/ in front of the link, or go to positive-feedback.com, go to archive, issue 1, at diy you will find it.
Johann
Old 30th May 2014, 07:12 PM   #9
Perhaps I'm biting off more than I can chew. Perhaps a community build is where I'm going. I am Ok with low power and will stick with 45 ' because I have 14 of them. I wanted to build an integrated that will accept 2V input. I have to sit down and draw out the whole schematic and add in the changes mention in the article and by Bill Epstein himself...I'm not good at that
Old 30th May 2014, 11:01 PM   #10
Check out the article at:
dagogo.com/the-simple-45
Push Pull stereo amp bridged to monoblock operation Tyimo Tubes / Valves 8 26th November 2013 10:47 PM
B&K M200 Monoblock Schematic ojdiazr Solid State 8 10th September 2013 10:05 PM
Advice on converting Yamaha B4 stereo to monoblock muddasirwaheedmalik Solid State 0 27th September 2012 08:21 PM
Look for Mark Levinson No.20 monoblock schematic andjur78 Solid State 1 7th June 2011 07:25 PM
Monoblock Vs Stereo samsagaz Everything Else 12 27th April 2009 10:21 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
