Webcor ceramic phono input circuitry suggestions? - diyAudio
Old 12th May 2014, 08:04 PM   #1
Default Webcor ceramic phono input circuitry suggestions?
Hi there - I've been updating the electronics in a Webcor 1863 phonograph and ran into this "CPI" input circuitry, which I'm inclined to replace. The schematic gives no values for resistors/capacitors in the package, and I'm uncertain of how to proceed. Any advice you could offer would be appreciated. This is a ceramic cartridge phono input in a "portable" suitcase style record player.
Old 12th May 2014, 08:58 PM   #2
This looks like some sort of loudness control. Why do you want to replace it? Is it damaged? If it still works but for whatever reason you want to replace it anyway, maybe you could measure its characteristics and reverse-engineer the exact contents of the yellow thing somehow, although it won't be easy.
Old 13th May 2014, 03:19 AM   #3
Hey Marcel - when this unit came to me it was only producing hum, so I began updating the old caps and thought to replace the CPI as well due to age and probable ceramic caps in the package. But I will button everything up and try it with the CPI in place unless someone has a similar circuit with values they can suggest! I've not been able to find one yet. Thanks for your reply!
Group Buy - Ettinger Ceramic Standoffs, Ceramic Strips and Solder Tags herrstagl Group Buys 9 20th July 2013 12:36 PM
Help and suggestions for My Phono and pre amp duderduderini Tubes / Valves 4 16th March 2013 09:27 PM
Ceramic Cap in Line Level Input RFI Filter? nereis Parts 6 13th November 2011 09:29 AM
ECC83 input circuitry newmiac Tubes / Valves 19 4th November 2011 06:48 PM
How Can I connect A Balanced RIAA Phono Pre-Amp to a Phono Plug amp input jmartinbaugh Analogue Source 3 25th April 2011 01:24 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
