Electrolytic cap question - diyAudio
Old 7th May 2014, 01:15 AM   #1
greg7 is offline greg7  United States
Default Electrolytic cap question
I'm replacing the electrolytic caps in my SE 300B amplifier. I'd like to try out Muse KZ and Silmic but the lead spacing isn't quite correct for the circuit board. Will putting a slight bend in the leads be an issue? I've read where this could affect the capacitance.
Old 7th May 2014, 01:37 AM   #2
KatieandDad's Avatar
That's perfectly in order and wont affect the performance of the caps.
Old 7th May 2014, 09:44 AM   #3
DF96 is offline DF96  England
If a website told you that bending electrolytic cap leads can affect the capacitance then you should avoid that website in future.
Old 7th May 2014, 11:33 AM   #4
vacuphile's Avatar
Well, it won't influence the capacitance, but you would want to keep the leads as short as possible so as to not introduce unnecessary inductance.
Old 7th May 2014, 12:48 PM   #5
At audio frequencies the inductance is negligible, the lengths of the PCB tracks or wires going to the cap will be far greater than the added lead length.
Old 7th May 2014, 12:51 PM   #6
chrish is offline chrish  Australia
chrish's Avatar
Is there anything wrong with the ones that are already in there? You might just be burning money for no reason. If you are looking at electrolytic, worth looking at the low ESR Panasonic. No voodoo, however
Question about Electrolytic Cap polarity whyvoltage Power Supplies 11 31st January 2014 05:00 PM
Question about old electrolytic cap tolerances Marcel_D Parts 6 7th August 2011 05:48 AM
Stupid electrolytic cap question....... firenewt Tubes / Valves 4 24th October 2006 12:26 PM
Electrolytic cap question (not quite covered elsewhere) Puggie Parts 5 15th March 2006 03:23 PM
can I use an electrolytic cap as coupling? Nordic Chip Amps 2 20th September 2005 09:12 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
