Real russian tubes anyone?? - Page 2 - diyAudio
Old 8th January 2004, 06:43 AM   #11
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
I can help you.. need to be a little more specific though. there are quite a few tubes that can do 10w SE.
Old 8th January 2004, 02:32 PM   #12
Magura is offline Magura  Denmark
Magura's Avatar
Originally posted by fdegrove
By linelevel is meant a CD or equivalent source not really requireing amplification even a lot of people use some.
Think low mu, low Zout tubes acting as semi-buffers to the amp.
That's a huge raft of tubes from triodes to pentodes...
Any preference for directly heated triodes or whatever?
Directly heated???
As you may have figured....im 100% new to tubes
Linelevel it is then.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 8th January 2004, 02:34 PM   #13
Magura's Avatar
You gotta aske the questions you need me to answer......so you need to be a little more specific
I havnt got a clue about tubes. I just stumbled on the option to build a tube amp for relatively little money, cause i can get the tubes more or less for free
Magura
Old 10th January 2004, 12:52 PM   #14
Hey-Hey!!!!,
For a beginner, I would recommend the Bottlehead assembly manuals. Nice linestage design, can be used with a whole raft of dual triodes. They have amplifiers which are directly heated,so that part of the circuitry is explained also.
The manuals are not to expensive and contain all technical specifications of the parts, so you can shop for other sources for your particular tube's requirements. They also have layout pictures, which will give you some idea of how things should be done, until you learn the detailed reasons yourself.
One thing, their stuff is all parallel feed in the output stage, and that is not absolutely the simplest thing to do, just one way to skin the proverbial cat. Thye have great skill at getting parts which are jsut adequate for the job at hand, although recently they have started offering Iron which has some reserve capacity in case you want to deviate radically from the original design. Very careful are those guys, and skilled...anyway, good luck getting your project off the ground, there is help all over the place.
regards,
Douglas
the Tnuctipun will return
Russian 6P14P tubes Ty_Bower Tubes / Valves 25 31st July 2016 09:17 AM
Russian tubes. fdegrove Tubes / Valves 39 2nd December 2011 03:12 AM
Russian tubes - what pin material? GlidingDutchman Tubes / Valves 8 14th July 2008 12:35 PM
Russian Tubes sdman Tubes / Valves 3 30th January 2006 01:41 AM
Copyright 1999-2017 diyAudio
