I'm starting 300B amp
Old 7th January 2004, 09:54 PM   #1
metalmaster is offline metalmaster  Poland
Default I'm starting 300B amp
Hi!!
I want know what you think about that schematic. If there are some mistakes or if I could do something better please give me advise. And that grid resistor is 1k no 1R, my mistake.
THX
Old 7th January 2004, 10:18 PM   #2
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Metalmaster,
Your schematic does not show...likely because it is to big in pixels...max is 800*600 and should not be bigger than 100k.
If you like you can send schematic to me and I will change and post it for you..
Bas
If you can see the speaker cone move...it's not hifi.
Old 7th January 2004, 11:07 PM   #3
Ok the pic.
Old 7th January 2004, 11:40 PM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Actually I think it's 800*1200 and no larger than 100Kb but more importantly, if you preview your post the image refuses to attach.
Frank
Old 8th January 2004, 01:52 AM   #5
fdegrove's Avatar
If it we're me I'd drive a 300B with a 2A3, trioded EL34 or similar, or take an entirely different road.
Frank
Old 8th January 2004, 01:55 AM   #6
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
hi frank, can you point me to an EL34-300B circuit that you would likely build.
Old 8th January 2004, 02:05 AM   #7
fdegrove's Avatar
Hmmm...memory tape going bzzzzzzzzzzz and bzzzzzzzzzz...
Can be done though....
Came up with zip...but...I do recall the WE91 mods of La Maison de L'Audiophile...Good sounds...
Good recipe too, a penthode driving a triode...Hold on...Ahhh...Thorsten Loesch, our "dondersteen"...
Bingo:
Thunderstone Loesch..........
Hope that helps,
Frank
Old 8th January 2004, 09:41 AM   #8
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Default Re: I'm starting 300B amp
Konnichiwa,
First, you can likely drop that resistor.
Secondly, your +B supply will have some nasty resonances, you probably want either more capacitance or inductance, damping resistors and you really want to tune this, best done in the first place in P-Spice and then finetuned in the Amp.
Thirdly, your gainstructure is a bit problematic. Your input can step up by no more than 1:4 by which time reflected input capacitance is at a srathospheric > 1nF making a seriously meaty preamp mandatory. The 300B Driver has a Mu of around 3.85 and the IT will not do more than 1:2 sensibly, even that should probably not be used. With around 80V Bias you will have 2V input sensitivity for full Output using a 1:4 input and a 1:2 interstage stepup, both of which will limit bandwidth and 4V input sensitivity for no interstage stepup.
Also, for "sound" reasons, you might wish to use a 10/10Y/VT-25 or similar as driver. People who have tried have liked the 10 or also the WE 205 (Sakuma) as driver for a 300B over many other valves. The circuit can remain as before, except the heaters should be around 6.5 - 7.5V DC @ 1.25A. You get a Mu of around 8 and you can use a lower power Interstage Transformer with likely better bandwidth.
If you are going to use DC Heaters, how about making the symmetrical and filtered via emitter follower "gyrators" or inductors?
Sayonara
Old 8th January 2004, 02:09 PM   #9
mcs is offline mcs  Denmark
I'm sure Lundahl will like it
Why do you use such a small cap value after the first choke? I would probably use 50F rather than 10F. And if you use such small cap values (10 or 50F), why not use paper or plastic caps rather than electrolytics?
Best regards,
Mikkel C. Simonsen
Old 8th January 2004, 06:28 PM   #10
Resistor and +B will be not a big problem. I can give one more voltage on transformer (7V) becouse thats not big cost and it give some possibility to experimentation and education - that is my first tube amp.
Im not sure what should I do with my gainstructure. That is my bigest problem
I'm starting 300B ampHide this!Advertise here!
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
starting out ineedahobby Chip Amps 3 15th October 2007 08:31 PM
starting over trailsnail85 Car Audio 6 12th December 2005 05:20 AM
Starting AMp up Wynand Chip Amps 2 25th August 2005 02:57 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
