Anyone tried this at home?
Old 7th January 2004, 04:38 PM   #1
universum is offline universum  Netherlands
universum's Avatar
Default Anyone tried this at home?
Wanna try this nice piece of Russian-art,It's stamped RK-71....but believe it's a GK71,when I am correct.Looks a lot like a 813 too.
Anyone familiar with this tubie?
Sure would help me:-))
Thanks in forward!
Arthur.
Vision is the Art of seeing things invisable.
Old 7th January 2004, 11:37 PM   #2
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
It is a GK71 but that tube isn't a 813.
Like most of those big bottles it's a transmitting tube, in casu a tetrode.
If you have a few spares they're certainly worth building with.
Love those graphite anodes...
Frank
Old 8th January 2004, 12:31 AM   #3
316a is offline 316a  England
316a's Avatar
Default Re: Anyone tried this at home?
Thanks in forward!
Arthur.
These valves look super-beefy and are on my 'to do' list ! Lit up with the lights off , very impressive looking . I estimate trioded Ra to be about 1.5k if the mug1g2/transconductance specs are anything to go by . After trying various triode strapped pentodes and tetrodes with anode voltages way over the g2 limit , 700V should be handled easily triode-strapped . I have built sockets already from teflon septars and will plot curves on the tester up to 400V , should give a good idea if my Ra guestimate is correct . One point to note : the heater requirements are a little on the 'nasty' side and will require DC for SE usage (20V heaters) , I doubt a hum pot and AC heating will be quiet enough . I'll post the triode test results once I've completed what's currently on the bench
316a
Old 8th January 2004, 06:13 AM   #4
universum's Avatar
Default graphite
Hi Frank,
That's what i thought too:-)
Would be a shame to leave them laying around...I have three of them left(gave two away to a friend),sure like the white filements once lit up looks like a bulb(no orange glow here:-))what a light!!
What should i put in front of these biggies?
I was thinking of an El-84 followed by an EL-34 and the the GK-71,but maybe I should stick to DHT's?Suggestions?
Thanks in forward!
Cheers:-))
Old 8th January 2004, 06:29 AM   #5
universum's Avatar
Default Re: Re: Anyone tried this at home?
316a
According to the specs the limit on g2 is 400 volt,so wanna be a bit on the save side,you really think they can handle up to 700 Volts?Was thinking of triode strapping and put an el-84 an EL-34 in front..(triode mode too:-)
Wanna try AC on the heaters too,if that doesn't work i can go to DC later:-)But I am very curious how your testresults develop:-)
Please keep me posted:-)
Let there be light!(can read my paper next to it:-))orange?...nah white!
Thank you all for your replies!
Old 8th January 2004, 06:53 AM   #6
Colt45 is offline Colt45  Serbia
Send a message via ICQ to Colt45
Here is a little bit of information, if you don't already have it.
just a couple graphs and some ratings.
Seems like an intresting tube.. cheap, powerful.. cool looking.
Damn heavy on the heater though! 60w.
edit: bah! forgot the link. Here it is.
http://www.qrz.ru/reference/tubes2/type2/gk71.shtml
Old 8th January 2004, 07:59 AM   #7
universum's Avatar
colt45 thanks...didn't have them with the graphs....only the russian keeps hunting me:-))
for those who like the glow see attachment...sure keeps me warm in winternights:-)
Old 8th January 2004, 11:13 AM   #8
316a's Avatar
Default Re: Re: Re: Anyone tried this at home?
YES Here's my prototype teflon socket
Did you use clip leads to light yours up ?
316a
http://www.auction.2y.net/user/bigdaddy/gk71skt.jpg
Old 8th January 2004, 01:33 PM   #9
universum's Avatar
Default Re: Re: Re: Re: Anyone tried this at home?
[QUOTE]Originally posted by 316a
[B]
WOW looking great!Did you make them yourself?Looks prof to me.
Don't have one:-(or two...do you sell?
Yes i did..whehehe,on 12 volt dc...only for the picture...
Well it's gonna be a while when i start the project,working on other amps that must be done first,then the nicer things..
What are you planning to make?
Old 8th January 2004, 01:55 PM   #10
316a's Avatar
Default Re: Re: Re: Re: Re: Anyone tried this at home?
[QUOTE]Originally posted by universum
[B]
12V DC ! Thats a bit wimpy . The things look far more impressive with 20V on them . The sockets are adapted from teflon septars . The contacts are removed and the holes opened up . I then insert bullet crimp shells inside the holes and use a slice of teflon with a nut and bolt to retain the contacts . Topcaps can be made from terminal blocks withe the connectors removed . I just drill out a slice of 1" teflon bar and push the teflon on to the connector once its screwed on to the topcap . None are for sale , you have to make them yourself but I do have a fair quantity of the septar sockets in stock in case you are interested in making some yourself . I should really get busy with the triode curves now......
316a
Anyone tried this at home?Hide this!Advertise here!
Home sub in a car? banshee Car Audio 7 5th December 2008 04:43 AM
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 12:40 AM
WFS for Home use? syntheticwave Everything Else 0 26th February 2008 09:08 PM
car sub for home madman29 Subwoofers 21 13th November 2006 09:14 PM
Home home or pop pop noise from sub ricky fong Multi-Way 0 26th February 2003 01:15 AM
