Anyone tried this at home? - Page 2 - diyAudio
Old 8th January 2004, 04:53 PM   #11
universum's Avatar
Default Re: Re: Re: Re: Re: Re: Anyone tried this at home?
Originally posted by 316a
12V DC ! Thats a bit wimpy . The things look far more impressive with 20V on them .
I know,tried before,then it's a really lightbulb!
The sockets are adapted from teflon septars . The contacts are removed and the holes opened up . I then insert bullet crimp shells inside the holes and use a slice of teflon with a nut and bolt to retain the contacts .
You have slices of teflon laying around...
Topcaps can be made from terminal blocks withe the connectors removed .
Have made a nice sort of "spring retainer" for that...All clamped nicely,and for high temp..
I just drill out a slice of 1" teflon bar and push the teflon on to the connector once its screwed on to the topcap . None are for sale , you have to make them yourself but I do have a fair quantity of the septar sockets in stock in case you are interested in making some yourself .
Well i sure am:-))
Maybe i can make you happy with something else to trade?
What do you really need,maybe i have it:-))
I should really get busy with the triode curves now......
OOOoops,yep...didn't want to disturb...:-))
Thanks,have a nice evening.
Arthur.
316a
Vision is the Art of seeing things invisable.
Old 27th January 2004, 06:57 PM   #12
316a is offline 316a  England
316a's Avatar
Default GK71 as a triode
Ran some tests last week on the AVO using an outboard filament supply . Limited by the AVO CT160 tester limits (400V / 100mA) , mu measured as 4 and gm at 2.6mA/V (approx 1.5k) at 60mA/250V . As I can only test up to 400V at present , 250V is about central for calculating mu which is very constant as was gm at various operating points for the same current . As current increases so will mu and Ra will decrease , I would expect Ra to approach 1k and mu to increase to 5 >100mA . Curves are similar to the 845 but lower Ra . Hopefully will have some 5K SE transformers wound in the next few months to see what the things can really do , unless anyone UK based has a pair of 5k SE outputs going begging
316a
Old 27th January 2004, 09:45 PM   #13
universum's Avatar
Default i have some
well there must be here somewhere:-))laying around...think i have some 7 k's...
thanks for the forework...
post when i am underway with the whole thing....but there are 4 amps before that to make...so i'll have to hurry:-))
happy listening!
Old 28th January 2004, 12:49 AM   #14
Here is a curve for the GK-71 I did a year or so ago. The curves are alot smoother than they look in the graph, but I plotted onto graph paper straight from the measurement, so I had a time getting it into a computer graph. Hope it's useful.
MichaelGK-71 Triode graph
Old 28th January 2004, 12:56 AM   #15
Second try at link
GK-71 Triode Graph
Old 28th January 2004, 01:01 AM   #16
Old 28th January 2004, 05:07 AM   #17
universum's Avatar
sorry still can't see them micheal
Old 28th January 2004, 10:55 AM   #18
Default picture problem
Sorry, don't know what the problem is. I tried linking to my website and attaching the file and neither one seems to work. If you want to email me I will send you the file. Use a subject line like GK-71 data else I might think it's junkmail.
Michael
Old 8th February 2004, 07:10 PM   #19
universum's Avatar
Thanks Michael....now i have to see when i've got some time on my hands to actually try it out.Let you know when i do..thanks again.
Home sub in a car? banshee Car Audio 7 5th December 2008 05:43 AM
Custom Home Theater Project in New Home, Opinions appreciated. thadman Multi-Way 5 20th November 2008 01:40 AM
WFS for Home use? syntheticwave Everything Else 0 26th February 2008 10:08 PM
car sub for home madman29 Subwoofers 21 13th November 2006 10:14 PM
Home home or pop pop noise from sub ricky fong Multi-Way 0 26th February 2003 02:15 AM
Copyright ©1999-2017 diyAudio
