K8011/K8010 PCB build thread
Old 18th August 2014, 06:26 PM   #11
jamesfeline is offline jamesfeline  United Kingdom
jamesfeline's Avatar
Hi
Ebay link for 2 new PCB's
valve amplifier PCB Velleman K8011 | eBay
Old 18th August 2014, 09:03 PM   #12
Hi
Please describe the fault in more detail as I can repair these units for you .. regards Nick
Old 19th August 2014, 11:20 AM   #13
Hi
Nick Again .. I have had a few requests if I could offer a full kit for k8010 & k8011 mono block amplifiers.
I have been thinking about a small business venture but the transformers would make the kits very expensive, or I could offer a small form factor kit without valves and the transformers
what do you all think ??
regards
Nick
Old 19th August 2014, 02:14 PM   #14
wicked1 is offline wicked1  United States
wicked1's Avatar
I'd think a full kit would mean less experienced builders and more questions.
Partial kit (no tubes or transformers) is good for slightly more advanced builders, and maybe more sales, as it's not such a big up-front expense for people.
Personally, I'd set up a simple website w/ some basic info and parts list w/ part numbers from a couple of electronics distributors, and just sell the PCB's. Then the builder can simply order the parts list for an easy build, or choose different components if they want.
Old 19th August 2014, 06:07 PM   #15
Hi
Excellent advice .. what I was thinking .. or a fully built unit fully tested and guaranteed
thanks for the help
Nick
Old 23rd August 2014, 09:37 AM   #16
Hi All
For all those people that have pm,d me I will upload some more photos tonight, hopefully have the new PCB running this weekend
90w RMS (class A up to 15 w)
regards
Nick
Old 7th September 2014, 12:09 PM   #17
Hi
Some more pics as the 1st PCB has now been fully populated, next stage is to add to the main chassis plate and connect all the switches and transformers. Also note I have mounted the 10 ohm cathode resistors off board for easy change out in case a valve pops .. which normally takes out the resistor. These are sized for 1w only as a safety feature, so they go open circuit as not to cause any more pcb track damage.
regards
Nick
Old 7th September 2014, 09:23 PM   #18
Hi
No one interested in my work .. oh well
Old 8th September 2014, 07:34 AM   #19
samb is offline samb  France
nick
wonderfull work
the PCB is populated as an art work
I notice that you have increased the value of HT capacitors.
But to be very efficient we should introduce a couple of resistors between
the capacitors an as the PSB is done it is impossible.
How long have you been involved in DIY to do things so neat?
Congratulations
Old 8th September 2014, 09:54 AM   #20
Hi
Thanks for the comments, have been making electronic projects since the age of 15 .. I am 50 next April
There is a small power resistor used a 5w 1 ohm at the output of the power supply
thanks for the comments
Nick
K8011/K8010 PCB build threadHide this!Advertise here!
VSSA Through-Hole-PCB build thread PMI Solid State 529 18th May 2015 01:18 AM
YAWSTB (Yet Another What Sub To Build) thread? oktyabr Subwoofers 5 8th July 2011 09:57 PM
Sorry another newbie build thread soupdragon Multi-Way 30 9th December 2008 05:29 PM
Velleman K8010 monoblock tube amplifiers bonnel Tubes / Valves 2 12th April 2008 10:07 PM
Velleman K8010 mjb Tubes / Valves 1 7th August 2004 06:55 AM
