K8011/K8010 PCB build thread
Old 14th February 2018, 09:58 PM   #111
jamesfeline is offline jamesfeline  United Kingdom
jamesfeline's Avatar
more updates over the weekend
Old 14th February 2018, 10:12 PM   #112
Matt BH is offline Matt BH  United Kingdom
I like the solder tag thing Nick. May be a good idea to get some nickel plated brass washers and put a little grease on the side the tag bolts up to (to stop the solder wicking round to the face the tags bolt to) before sweating them on to the board. Directly bolting tags to a tinned PCB track will cause problems over time. There are proper inserts for this but they are crazy expensive unless you buy in thousands.
Any pics with the new output transformers?
Cheers
Matt.
K8011/K8010 PCB build threadHide this!Advertise here!
VSSA Through-Hole-PCB build thread PMI Solid State 529 18th May 2015 01:18 AM
YAWSTB (Yet Another What Sub To Build) thread? oktyabr Subwoofers 5 8th July 2011 09:57 PM
Sorry another newbie build thread soupdragon Multi-Way 30 9th December 2008 05:29 PM
Velleman K8010 monoblock tube amplifiers bonnel Tubes / Valves 2 12th April 2008 10:07 PM
Velleman K8010 mjb Tubes / Valves 1 7th August 2004 06:55 AM
