What's the Best Way to Reduce Gain in a Preamp
Old 18th April 2014, 03:46 PM   #1
rcollege is offline rcollege  United States
Default What's the Best Way to Reduce Gain in a Preamp
Hi all,
This forum is so helpful...Thank you all!
Here's another question I hope will help me and others.
I have too much gain in a preamp. I'm using 6J5gt's or 6C5gt's in a simple SE circuit.
What is the best way to reduce gain?
I am using a 50k linear pot along with 7.5k resistor after the pot.
I am using a load resistance of 12.5k
Lower load resistor value?
Use cathode resistor and bypass cap?
Higher pot value?
Increase input resistance?
Find lower Mu Tubes? Triode connected pentodes? I have EL34's, 6V6's and 6DJ6's.
Any comments are welcome.
Old 18th April 2014, 04:23 PM   #2
funk1980 is offline funk1980  Netherlands
funk1980's Avatar
There are tons of ways to lower the gain, but a schematic would help to determine which would best suite you preamp.
Old 18th April 2014, 04:25 PM   #3
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Do you actually need any amplification at all ?
Old 18th April 2014, 05:38 PM   #4
tomchr is offline tomchr  Canada
tomchr's Avatar
Without a schematic, it's nearly impossible to give advice for your specific circuit. I'm guessing the better options will be to use a tube with a lower mu or use an un-bypassed cathode resistor. But without a schematic, we're shooting in the dark here...
Messing with the volume pot will have little to no effect.
~Tom
Sizzling Summer Sale going now through August 31st, 2017: Modulus-86, Modulus-286, HP-1, DG300B, and more are all on sale.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 18th April 2014, 06:10 PM   #5
Andyroid is offline Andyroid
If you just want to throw away some gain without affecting tone then I suggest splitting a plate load resistor in two, making a voltage divider. Done early in the amp it may give 'more headroom' but worse s/n ratio. Without a schematic...
Old 18th April 2014, 07:13 PM   #6
Thank you all,
I completely understand about the need to see the schematic.
I quickly drew it up.
Thanks again
Old 18th April 2014, 08:56 PM   #7
Ketje is offline Ketje  Belgium
Ketje's Avatar
Wrong way
Try it like this
Mona
Old 18th April 2014, 10:25 PM   #8
aardvarkash10 is offline aardvarkash10  New Zealand
aardvarkash10's Avatar
you need to define what the source voltage is, and what the required drive to the amp is. Without that, everyone is giving well-intentioned best guesses.
I suspect that a simple cathode follower is what you need. But without the info above, I'm guessing too.
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Old 18th April 2014, 10:28 PM   #9
jerluwoo is offline jerluwoo  United States
jerluwoo's Avatar
Ketje has it right on the volume pot being wrong. I notice you are basically trying to use it at the generic operating point from the datasheets, plate voltage 90V, grid 0V, 10mA plate current. What they don't mention is that this is with a B+ voltage in excess of 300V, so the load resistor can be a sizable value. If you want to add distortion for that "tube" sound, this setup is fine.
Old 19th April 2014, 04:46 AM   #10
stocktrader200 is offline stocktrader200  Canada
place a 150k in series with a 15k to ground. Take the output across the 15k
What's the Best Way to Reduce Gain in a PreampHide this!Advertise here!
Reduce gain on power amp? scutterflux Tubes / Valves 20 28th December 2012 09:08 PM
Aleph_Ono reduce gain ? nar Pass Labs 11 17th November 2011 08:07 AM
How to reduce gain in mu-follower? karsten21 Tubes / Valves 9 30th June 2011 10:31 PM
How to reduce gain of this Tube Preamplifier ? ANALOG GUY Tubes / Valves 5 22nd September 2006 03:37 AM
Reduce Input Gain Question? mgreene Chip Amps 9 27th April 2004 11:32 AM
Copyright ©1999-2017 diyAudio
