Joined 2009
You are describing a linear pot behaviour, use 100k Audio or Log and everything will be fine.I m using a 100K volume, just 2 steps from the beginning already too loud
No need to mod preamp.
OK, 100K:390 attenuation is whopping 48dB
IF that is already too loud, you have WAY too much gain, and that´s an understatement.
Get rid of that 20dB gain preamp and even so I am not sure it will be enough.
Go fully passive, or, if driving a LONG cable, add a buffer.
Tube type if you wish, but the point is unity gain.
Not really needed with, say, under 1 meter cables.
By the way, bigun said the same and rayma hinted at it.
Maybe there´s a reason we all agree on diagnostic.
yes, there are a lot of options, first one being the volume control, but you can still set that line stage to unity gain if you just need buffering....a switch will come in handy....no guaranties you will like it better than if you just use a passive volume control preamp...
- Tubes / Valves
- What's the Best Way to Reduce Gain in a Preamp
