Driver vs Power tube - diyAudio
Old 16th April 2014, 03:23 AM   #1
Default Driver vs Power tube
I am learning as much as I can about tube amps, and Im wondering what determines whether a tube can be a driver or power tube? For example, I came across some old tubes from 1940s Rl 15T 12. It's a triode "transmitting tube". I also read that it has been used in low power Monoblocks. If one knows the characteristics of a given tube, how does that determine the necessary driver tube?
Old 16th April 2014, 08:29 AM   #2
artosalo's Avatar
The characteristics of an output tube determines the condition that the driver stage must fulfil. Two basic situations exist.
In most typical case the output tube requires only signal voltage drive, not current, i.e. no power is needed.
In some case of transmitting triode like 811A it requires also grid current to be driven, i.e. power is needed.
These two cases are very different and the latter is more demanding for driver stage.
Old 16th April 2014, 08:54 AM   #3
M Gregg is offline M Gregg  England
Just a thought,
Stupid question..but I'll ask it.
What are the thoughts regards the following:
If we have a tube concertina type phase splitter and replace the tube with a FET how does that effect the voltage dropped across the device.
Ie voltage swing out to the power tubes, if both have the same supply voltage and headroom for the swing?
Eg if it was possible to have no voltage dropped across the PI device (set mid point of supply)how would that effect the voltage swing to drive the tubes?
M. Gregg
Old 16th April 2014, 09:55 AM   #4
Just for interest,
I guess it should say new old phase splitter.
New Phase Splitter
And part of the answer is are you driving a triode or a pentode power tube.
M. Gregg
Old 16th April 2014, 10:18 AM   #5
funk1980's Avatar
Originally Posted by M Gregg View Post
Just a thought,
M. Gregg
It would make a very bad concertina PI. It will only do it's job when the gate goes more negative. If there's no voltage drop across the PI device, so the output's operating point would be the same, as soon as the anode output goes down and cathode output goes up (grid/gate voltage increases) they clip. They can't 'cross into each others realm' so to speak. The voltage drop across the PI sets the headroom for this part of the input signal. You can increase the drop across the MOSFET, but that would defeat the purpose of the question.
Old 16th April 2014, 10:29 AM   #6
Yes ,
I was thinking about the voltage drop across the device limiting the output swing. It would have to be balanced.
M. Gregg
Old 16th April 2014, 10:31 AM   #7
funk1980's Avatar
Yes ,
M. Gregg
Exactly! Most concertina PI's have 1/4 HT across anode and cathode load. The other half is across the tube to set the headroom.
But like I said. It can be done with a MOSFET. If you bias the gate asymmetrically, you get a very linear, low output impedance 'modern' concertina.
Old 16th April 2014, 10:34 AM   #8
Do you have any links to working examples?
M. Gregg
Old 16th April 2014, 10:43 AM   #9
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
If you DC couple to the previous stage then there's nothing to it; just replace the old cathodyne triode with a MOSFET. For maximum swing, the gate should rest at about 1/4 HT (same as for a pentode when you think about it). (For a triode cathodyne the grid should rest at about 1/6 HT for maximum swing, although with a triode it is more dependent on load).
Old 16th April 2014, 10:43 AM   #10
funk1980's Avatar
I've got this quick-n-dirty LTSpice simulation. I've not done the math or optimize the values otherwise, but it's a point I'd be comfortable to start experimenting with. Output impedance is around 12 ohm, but could be improved I'm sure.
Thanks for the idea !
The Best Way To Separate L+R and Driver/Output Tube Power Supply ? HP8903B Tubes / Valves 9 10th August 2013 06:43 PM
Driver Tube Power Supply Question ? HP8903B Tubes / Valves 9 16th February 2013 11:35 AM
Tube driver for a SS power amplifier gianmaria Tubes / Valves 21 6th September 2005 01:09 PM
Replacing a power tube (used as driver for mosfet car amp)...how to bias? 00christian00 Tubes / Valves 33 30th June 2005 02:41 AM
Copyright 1999-2017 diyAudio
