| diyAudio Sponsor | ||
I´m planning to biuld a tube amp with the 845 or 211 tube.
I saw an article in http://www.ptsoundlab.free.fr/sectub...mas/845/84518w The idea was published in "La revue LED". Has anyone experience with this kind of tube or has even built this amp? Or is the 211 tube the better choise (e.g. J. LeBong211SE) when 8 - 10 Watt are more then enough to drive my speakers. I want an tube amp (SE without feedback) for the mids and highs which sound very open and naturell. Any different ideas? regards Günter |
#2 | |
Previously: Kuei Yang Wang
Konnichiwa,
I would argue that anyone who "needs a schematic" should perhaps avoid building something as potentially lethal and problematic as a 211/845 untill they have more experience. Sayonara |
#3 |
Thank´s for your good advice. I have built many Class A transistor-amps (Aleph, ZEN, Hiraga, JLH). The JLH and the Hiraga are very, very good sounding amp if 10 Watt are enough.
Now I want to build something different like tube-amps, but with also excellent sound. It need not necesserilly be a 845 or 211 tube. I just want an triode tube amp with minimum 5 Watt SE without using feedback. I´m dependent on a good scheme, because this would be my first tube project. regards Günter |
#4 |
Another suggestion is the excellent and high duty 6C41C, the little brother of the 6C33B, with much more stable bias.
This tube is rated to 320mA, runs around 160mA at 150Vak and mu 2.8. It will dissipate 25W on the plate, so you can pull around 10W in SE, similar to a 211, or two will deliver almost 20W. I believe Bas has built one; he has good tips. Cheers, Hugh |
#5 | |
Konnichiwa,
http://www.lundahl.se/claus_b_se.html (sorry, HTTP button seems not work right now) The same Amplifier Chassis (if implemented well and build with a view to future Modifications/Expansion) can be converted to use 2A3 and/or 300B output valves and different driver circuitry, keeping all the transformers and the chassis, which are the expensive and labour intensive parts of a n amplifier. Sayonara |
#6 |
I'm going to build a 845 SET but low voltage. I don't see why not, and others have done it. Bearing in mind also that Chinese 845s are very cheap (£29 in the UK). Possible operating points are, with the Hammond 125ESE (80mA DC) @ 5K
80mA 300v -21v 80mA 350v -31v 80mA 400v -40v Or with 100mA DC and a bigger OPT: 100mA 300 -15 100mA 350 -25 100mA 400 -33 www.heartofclay.com/eb/vamp.jpg www.heartofclay.com/eb/vamp2.jpg the above shows one solution. But surely a good SRPP could drive the 845 directly at these lower voltages. apparently it sounds magical. Plus 125ESE and chinese 845 make a pretty cheap project. why not? Any other suggestions for operating points and a suitable front end? |
#7 |
I´m sure now; the 211 and the 845 at high voltage are not a projects for a tube-beginner.
Hugh: I found a very interessting webside with the 6c45. http://www.digilander.libero.it/paen...e_CIRCUITS.htm I think I´m starting with the single ended version. The low voltage 845 is also very interesting. The output transformer could be the same as in the 6c45 project. Thank´s for help. Günter |
#8 |
HI
Look hire. Its not so much expensive tube and final efects are very good. http://republika.pl/diytriode/drugi_eng.htm |
| 40w Class A Circuit | kaybe | Solid State | 3 | 23rd February 2009 10:47 PM |
| JHL Class A ,Higher power circuit, 40W Class A | nicolas888 | Solid State | 8 | 13th April 2006 05:27 PM |
| Good bridge circuit | soundNERD | Chip Amps | 0 | 16th September 2004 10:03 PM |
| Whats a Good 6L6 circuit? | hacknet | Tubes / Valves | 34 | 25th April 2004 08:31 PM |
| good simple SE circuit please | Raj1 | Tubes / Valves | 35 | 29th November 2003 10:14 PM |
| Page generated in 0.09936 seconds (85.61% PHP - 14.39% MySQL) with 10 queries |
