Biasing a Class A amp information
Old 6th January 2004, 04:43 AM   #1
firebird josh is offline firebird josh  United States
Default Biasing a Class A amp information
I am trying to show the results biasing has on tubes for class A amps. What difference will biasing make on the shape of the wave (if it does anything at all)? Any place for info on this? Thanks alot.
Old 6th January 2004, 08:44 AM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
SE or PP?
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 6th January 2004, 12:34 PM   #3
maylar is offline maylar  United States
Biasing moves the quescent point up or down on the load line. It's easier to envision what happens if you have the characteristic curves of the tube in front of you. The load line is from supply voltage (V+) to max plate current (V+/RL).
Normal Class A operation is to bias the tube such that plate current is 1/2 of V+/RL. That gives the most output voltage swing. As you move the quescent point either way it takes less input voltage to reach the non-linear regions of the curve (output will clip sooner).
dave
Old 6th January 2004, 07:38 PM   #4
Its for a SE Hi Octane built form AX84.com. I am trying to write a report on how biasing affects the performance.
Biasing a Class A amp informationHide this!Advertise here!
Op amp class A biasing. pro Solid State 54 26th September 2016 10:01 AM
New class A biasing (with non-switching class AB overflow) Steven Solid State 34 24th March 2007 07:40 PM
low-biasing or high biasing in Class-AB amps Workhorse Solid State 124 18th October 2005 05:45 AM
