Made a new tube amp, 6J5 +27 +45 - diyAudio
Old 9th April 2014, 09:43 AM   #1
TURING is offline TURING  China
Default Made a new tube amp, 6J5 +27 +45
Made a new tube amp, 6J5 +27 +45.
cnc winding machine manually wound output transformer. 10mm thick aluminum diamond plate milling machine as a tube amp.
Old 9th April 2014, 09:50 AM   #2
working
Old 9th April 2014, 09:56 AM   #3
go on
Old 9th April 2014, 10:08 AM   #4
Diy fun all in one.
Old 9th April 2014, 10:50 AM   #5
Airhead is offline Airhead  Finland
Nice workmanship. I love the idea of using large chassis handles as support for rubber feets.
Old 9th April 2014, 11:38 AM   #6
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Very nice.
Would you please post the schematic?
Old 9th April 2014, 11:53 AM   #7
schematic
Old 9th April 2014, 04:43 PM   #8
Vinylsavor's Avatar
Hi!
Very beautiful build! Nice compact design!
I would expect the input sensitivity to be very high with the two cascaded stages with 6J5 and 27.
Best regards
Thomas
http://vinylsavor.blogspot.com/
Old 9th April 2014, 05:05 PM   #9
azazello's Avatar
Awesome!! /But why You use cap shunts 100V, if cathode points have 2 and 13 v,....and 240 v in point with 55 v?. Caps work with good dynamic on level about 70-80 % from max./.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 9th April 2014, 06:35 PM   #10
Originally Posted by Vinylsavor View Post
Hi!
Best regards
Thomas
0.5v full drive 45. 6J5 enlarged about 15 times, 27 times zoom around 6-7 overall put in a lot about 100-fold.
45 tube amp schematic castorG Tubes / Valves 26 21st August 2013 10:23 AM
10Y, 26, 27 and 45: relative microphonics rick57 Tubes / Valves 38 30th December 2010 11:38 PM
27 driving 2A3/45/ or 300B jmillerdoc Tubes / Valves 2 22nd December 2009 07:23 PM
Tube designs: 45 driving 45/2a3/300b? Veniogenesis Tubes / Valves 4 23rd April 2007 06:59 PM
#27 tube for line amp? Original Burnedfingers Tubes / Valves 12 21st December 2003 12:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
