Diff amp driver -> SE output
Old 8th January 2004, 01:08 AM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Universum,
What you're proposing is what is called a "Ripplekiller".
As you describe it it injects the ripple from the PS into the grid of the triode and you then take it of the plate out phase where it mostly cancels out.
What you don't mention is that this cause a voltage drop in the PS...No free lunch in electronics.
Frank
Old 8th January 2004, 01:14 AM   #12
Saurav is offline Saurav
I have a kind of ripple reduction thing in there already, the cap from B+ to cathode described in Tubecad. I need to get better caps for that and the cathode bias cap on the 2A3. The noise/hum level isn't too bad now, I don't really care as long as it's inaudible from my listening position during late night listening.
So will the triode provide any voltage regulation, or is this just a hum reduction circuit?
I don't have a cathode resistor now, I have a battery under the cathode. Thanks for the idea though, that's not something I'd thought about.
Frank, I understand what you mean about keeping the resistors as low as possible. I think, anyway I have a 100MHz scope, and it isn't too good when the timebase is turned all the way up. Nevertheless, I've used it to get a general feel for the level of hash in the circuit (just looking at the fuzziness of the trace), and maybe I can use that to determine oscillations on the tube in a similar way.
Old 8th January 2004, 01:29 AM   #13
fdegrove's Avatar
Know what ya mean...Pretty clever trick.
Nah...It reduces ripple.
Since there's no voltage reference and comparator it can't track anything but it provides some extra isolation from the B+ nonetheless, not a bad thing to have.
I could explain in detail but I think you got the picture already.
Sure, you can use that scope for that.
Frank
Old 8th January 2004, 05:42 AM   #14
Understood regarding the spare triode thing, but maybe the better solution is to switch the driver stage to 6C45pis. OK, maybe not better, but more fun
Thanks for the help.
Diff amp driver -> SE outputHide this!Advertise here!
Looking for very simple output driver. Douchekop Solid State 6 5th March 2005 05:59 PM
Output stage/preamp with gain: X-Bosoz with diff.-pair? Onvinyl Pass Labs 1 19th July 2004 09:29 AM
help with diff. output Raj1 Digital Source 4 9th September 2003 06:03 PM
driver stage for CFP output. RichardJones Solid State 0 21st April 2003 08:46 PM
output mosfet driver lazy Solid State 5 30th March 2002 05:13 AM
