Amplifier for active bookshelf speakers
Old 1st April 2014, 11:57 AM   #1
hugligan is offline hugligan  Sweden
Default Amplifier for active bookshelf speakers
Hello everyone!
A couple a months ago i bought a Yaqin MC-13S tube amplifier for my fullrange diy speakers.
Now i've completed my second speaker project consisting of:
Woofer: Scanspeak 15w8530k00
Tweeter: Bohlender Graebener Neo3PDRW
I will use a nanoDigi from miniDSP to actively filter these speakers. I would want to use the tube amp i already have for the woofers but need to get another amplifier for the tweeters.
Ive found this one: 6N2+6P1
Rated at 5W @ 8ohms and the tweeters are 20W @ 4 ohms.
I would like to have your opinion on wether or not this is a good ide? Would you recommend me getting this or maybe a Sure tk2050 4x100W for the whole setup?
Im not sure..
Thanks for your help!
Old 1st April 2014, 01:12 PM   #2
R.I.P.
Your main amp is basically a push pull ultra linear EL34 type.
You need about 1/3 to 1/4 of the bassmid power for the treble.
Don't believe that 5W rating for a second, it is simply not on,
not by a long, long way, especially SE and 4 ohms load.
Make a decent headphone amplifier, not much else.
Something like the above push pull valve complement will output
a real > 5W (say 8W?) into 4 ohms. FWIW for treble use you
can get away with quite small (i.e. cheaper) output transformers.
The basic type is quite common, and the prices do vary.
rgds, sreten.
Old 1st April 2014, 04:09 PM   #3
Ok i feared something like that.
Say i got the amplifier you showed above, how can i make sure that the volume is the same on the tweeter and the woofers?
What do you mean with output transformer? Like a class-d amp?
hugligan
Old 2nd April 2014, 04:47 AM   #4
TheTubeAmper is offline TheTubeAmper  United States
TheTubeAmper's Avatar
hugligan
As far as output transformers go, nearly all tube amps will have one, whether it be class A or not (with some exceptions including OTL or output transformerless amps). What sreten was saying is that physically small output transformers usually have bad low range fequency response, but since your only powering tweeters with it, small transformers are fine.
I don't know much about the minidsp but you might want to see if it can also allow you to adjust the balance of volume between the woofers and tweeters.
Read and Follow my posTs at your own discretion, and risk. I'm an Electronics and Audio Hobbyist who likes tube amps too! Please check out my projects at http://thetubeamper.com/
Old 2nd April 2014, 01:26 PM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
If you use an amp like the one shown by sreten, you only need to adjust the balance on one amplifier to set the overall response. After that use a volume control preceding the nanoDigi or digital volume control within it.
I built a 6P1P PP amp and it delivers an honest 8W in full class A.
http://img12.imageshack.us/img12/751...ittingdone.jpg
in this thread:
Sven 6P1P PP Amp
Old 2nd April 2014, 04:54 PM   #6
Ah I see now. Sounds pretty good, then i can suffice with a cheapish tube amp like that Music Angel. I think ill go for that one.
in this thread:
Sven 6P1P PP Amp
That's true, when i have a good combo ill leave the amps and just adjust on my computer and the nanoDigi (it has built in IR for volume and source).
Will it be hard to find the right treble level or will i hear it directly whats suitable ?
Thanks for the replies, truely valuable!
Amplifier for active bookshelf speakersHide this!Advertise here!
Which speakers to buy for bookshelf speakers timkoh Full Range 21 5th February 2015 11:52 PM
Converted a passive bookshelf to an active bi-amped studio monitor. 0x4452 Multi-Way 6 18th February 2014 09:33 PM
Active Bookshelf Speakers Chip Amp samer0214 Chip Amps 12 27th March 2012 01:58 AM
Amplifier modules for active speakers andy19191 Solid State 8 6th March 2010 01:59 PM
bookshelf speakers - need help ziv_r Multi-Way 1 24th April 2006 12:20 PM
