Valve amp - maintenance - diyAudio
Old 31st March 2014, 10:20 PM   #1
lexer98 is offline lexer98  Argentina
lexer98's Avatar
Default Valve amp - maintenance
Hello valve guys ... i have a very old Ken Brown Stereo with valve amp, according to my calculations have more than 40yr old (My grandfather bought it when he married).
I would like to do a maintenance, because the only thing that was changed are the valves
1-Which things would have to change?
>Pots ... all pots add noise and the shaft does not slide smoothly
> Capacitors ?
>Valves ? ... two valves have burns marks
>Resistors ?
2-One transformer make a lot of noise when turn up the volumen,
in the video is barely noticeable but it is very annoying noise IRL ¿ any way to fix that ?
https://www.youtube.com/watch?v=k2P2Aa2CyHg
Pics of the valves and interiors ... sorry for the quality
Valve 1
Valve 2
Interiors
Pots
Sorry for my horrible English
Old 1st April 2014, 04:13 AM   #2
hello ,
the amplificator is 1 way or 2 ways ?
so possible listing to all valve ?
they all résistor is not good to very performance , so possible change for news résistor !
possible change capacitor to risk burn !!!
look me old amplificator 2 ways , so first use is 1965 years
i me reconditioneded to old component for news perfs , change valve ( EZ81 , 12AX7S and 6P14P-EV )
File Type: jpg Ampli Stéréo EL84 - dessus - 31-03-2014.JPG (219.4 KB, 55 views)
File Type: jpg Ampli Stéréo EL84 - dessous - 31-03-2014.JPG (222.0 KB, 59 views)
Old 1st April 2014, 05:44 AM   #3
lexer98's Avatar
Thanks for the response jean ... is 2-way amplifier ... here is more specs
Power valves : 4X ECL82 ( Two per channel)
Pre-amp valve: 12AX7
AM valve: ECH81
The transformer makes noise when turn up the volumen to high (over 75%) or when a play music with much bass, i was think maybe the vanish is bad due the time and make the transformer plates vibrating ....
Here is one pic from internet , the transformer pointed is that make noise ...
Old 1st April 2014, 06:36 AM   #4
Tesla88 is offline Tesla88  Italy
Tesla88's Avatar
About transformer noise, try tighten up the transformer laminations and transformer chassis screws.
Old 1st April 2014, 06:39 AM   #5
hello ,
so possible all problem !
1 = looking impédance primary OPT to not valve connected to 2 ways for comparate to Ohmeter .
2 = possible use corrector in Baxendall is very up perfomance to saturate OPT .
3 = looking in osscilloscope 2 ways for analyse the problem to 1 Khz in 4/8 Ohms HP ( or charge fictive ) .
Old 1st April 2014, 07:09 AM   #6
lexer98's Avatar
Originally Posted by jean michel View Post
hello ,
Really thanks for the responses ! ... first i will check the transformer coils as sujected by jean and is all are good .. I'll varnish and tighten the transformer laminations
Old 1st April 2014, 08:49 AM   #7
DF96 is offline DF96  England
An amp built with 1970's components is likely to be fine, apart from any ageing electrolytic capacitors. Tropical fish caps last a long time. However, they are polyester dielectric - popular in guitar amps but can add a tiny amount of distortion. Up to you - I would leave them so the amp is authentic of its era.
The pots can be cleaned or replaced.
Valves can be replaced if necessary - check DC voltages.
Basically I would only change what is faulty, which may be nothing at all.
Old 1st April 2014, 05:35 PM   #8
Refugee1's Avatar
Last time I had a transformer that made mechanical noise I took the steel frame off and fitted it back with a shot of silicone rubber.
It worked.
Old 1st April 2014, 07:21 PM   #9
lexer98's Avatar
Thanks DF96 and Refugee !! ... hand to the work !
How identify if a valve is bad measuring DC voltage ? can you explain me ?. Thanks
Old 1st April 2014, 07:29 PM   #10
Compare the measured DC voltages with a service sheet. If within 20% then probably OK.
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 04:11 AM
Vintage amp maintenance TP143 Solid State 7 5th April 2012 07:56 AM
First tube amp, it needs maintenance flyingsquirrelman Tubes / Valves 3 23rd July 2010 03:53 AM
Yamaha M-80 amp mods/maintenance dognut Solid State 1 8th March 2010 09:35 PM
Valve pre-amp maintenance and purchase Commited Tubes / Valves 221 20th January 2006 07:15 PM
Copyright ©1999-2017 diyAudio
