Valve amp - maintenance - Page 2 - diyAudio
Old 2nd April 2014, 01:28 AM   #11
lexer98 is offline lexer98  Argentina
lexer98's Avatar
I fixed the transformer
In this picture you can see one of the laminations is arched ..
So i pressed with a clamp and immersed the transformer in insulation varnish
Guala ! ... now is really quiet even a full vol.
Unfortunately while trying to clean the potentiometers, i damage one capacitor of the tone control, but I saw a couple that are cracked, so is needed replace all
Originally Posted by DF96 View Post
Compare the measured DC voltages with a service sheet. If within 20% then probably OK.
Oke doke !
Sorry for my horrible English
Old 2nd April 2014, 09:34 AM   #12
DF96 is offline DF96  England
Tropical fish caps often get a little cracking where the wires come out. Nothing to worry about if that is all it is. If the main body is cracked then replace.
Old 5th April 2014, 12:35 AM   #13
lexer98's Avatar
I could solve all problems ... found some resistors a bit brown and a cracked capacitor on the pre-amp valve so i changed
Now is rocking like a boss ! ... i will build some full range speakers for this amp because the originals were eaten by moths
Sorry for the quality of the video, my potato not record so well
https://www.youtube.com/watch?v=EwJoPovS06s
Thanks for the support guys
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 05:11 AM
Vintage amp maintenance TP143 Solid State 7 5th April 2012 08:56 AM
First tube amp, it needs maintenance flyingsquirrelman Tubes / Valves 3 23rd July 2010 04:53 AM
Yamaha M-80 amp mods/maintenance dognut Solid State 1 8th March 2010 10:35 PM
Valve pre-amp maintenance and purchase Commited Tubes / Valves 221 20th January 2006 08:15 PM
Copyright 1999-2017 diyAudio
