6v6 family tubes
diyAudio Senior Member
Joined 2002
Not sure how large you want your "family" to be but I don't think this one is related to the 6V6.
Miniature base: EL90, 6AQ5, N727, 6L31, CV1862 etc. ,
Noval base: 6P1P (Russia, slightly different) and 6P1 (China, also different from 6P1P), different pin out: 6BW6. 6287.
Octal: VT107, CV510, 6AY5, OSW3106, 6F6 should work too.
Ciao, ;)
No, the 6CW5 is not similar to the 6V6. It is a 6BQ5/EL84 with a high gain screen grid which must not be fed over 300 volts, usually quite a bit less.
The 6EZ5 was on the dollar list at the usual places a few years ago until I mentioned that it plugged right into a 6V6 socket in many applications including the SSE. Now they are $5. The 6EY5 may work too, but I haven't tried that one.
yes George, the 12w6, and a lot of other tv tubes that used to sell for $1 a few years ago now sells for over $4, the 12W6 sounded so fabulous in my pp amp...
http://www.diyaudio.com/forums/tubes-valves/211254-those-magnificient-television-tubes-4.html
FWIW I finally tried some NOS 6EZ5 and 6EY6 tubes I bought a few years back in a new build...and as was said they pull waaay more current than a 6V6 so a rebias is definitely in order i.e. read 18V across a 250 ohm shared cathode resistor in a PP amp with a 6V6's installed and got 24V with a 6EZ5 or 6EY6.
I hope this is not hijacking the thread - I wanted to ask the '6V6 gurus' a question about this tube. I am looking to use it in a 'heavy driver' stage. 6V6 attracts me because of the beautiful triode curves and low Rp.
What's the maximum safe working voltage for this tube? I know what the spec sheets say obviously - but could I get away with say 15mA CCS per side in a push - pull choke loaded LTP with B+ at 500-525V, but the 6V6 plate idling at 300V? I would be using the Electroharmonix GT version.
PRR
Joined 2003
Fender guitar amplifiers often run 6V6 over 400V all night long. 440V is not uncommon, and 500V has been seen.
I think the 315-350V rating was both conservative and Marketing. You don't need over 250V to get full Class A power with decently low impedances. If you really want "more!", buy the bigger/costlier 6L6 or 807; that's why they exist. Ah, but Fender kept pushing the little shot-glass 6V6 and didn't find much problem.
