Finally started on my 6L6 amp. Need tube suggestions. Finally started on my 6L6 amp. Need tube suggestions. - diyAudio
Old 29th March 2014, 08:17 AM   #1
lazzer408 is offline lazzer408  United States
lazzer408's Avatar
Default Finally started on my 6L6 amp. Need tube suggestions.
About to start on my 6L6 PP amp but I thought I'd ask for opinions on a few things.
I have the following to play with.
400v B+
12AU7
12AX7
6SN7
6EU7
6L6
I'm quite happy with the floating paraphase inverter I used on my 6V6 PP amp but it could use a little more gain. I do like the cathodyne PI too. Any suggestions using drivers after a PI or should I just drive the 6L6s with the PI?
Old 29th March 2014, 08:33 AM   #2
multi is offline multi  Australia
Are you going to run the 6L6 as Pentodes, Ultralinear or Triode?
Phil
Old 29th March 2014, 08:38 AM   #3
lazzer408's Avatar
Pentodes for now. At the moment I don't have UL OPTs for it.
Class of operation will be AB.
Old 29th March 2014, 12:58 PM   #4
Parafeed813 is offline Parafeed813  Netherlands
My 6l6 amps were inspired by the 6L6 AB2 thread here.
It has an LTP splitter (5814a) into an LTP driver (6SN7) and a MOSFET buffer for the AB2 grid current.
The 6L6GCs run at 440V in triode mode, no NFB.
Plenty of power and I like the sound.
Old 29th March 2014, 01:52 PM   #5
artosalo is offline artosalo  Finland
artosalo's Avatar
Originally Posted by lazzer408 View Post
...I do like the cathodyne PI too. Any suggestions using drivers after a PI or should I just drive the 6L6s with the PI?
Cathodyne works very well and no drivers are needed.
Here is one version of 6L6 PP I have done:
Old 29th March 2014, 02:24 PM   #6
dirkwright is offline dirkwright  United States
dirkwright's Avatar
Yeah, with the outputs in pentode mode, they are sensitive enough not to need a driver stage. You would have to modify it unless you want to provide a negative supply.
Old 29th March 2014, 08:47 PM   #7
lazzer408's Avatar
Would a 6SN7 work in place of the 6SL7. Gain is much lower. Or 12AT7?
Old 30th March 2014, 05:59 AM   #8
artosalo's Avatar
The sensitivity would be quite poor with 6SN7.
If you want to use 12AT7, 6SN7, etc. then a LTP phase inverter with one voltage amplifying stage is better topology.
Something like this:
Old 1st April 2014, 01:45 AM   #9
lazzer408's Avatar
I got one channel done. Wired a 12AX7 as a floating paraphase. With only one channel wired, B+ sits at 420v with screen supply at 400v. What should the screen voltage be? Datasheet calls for 400v B+, 300v screen.
Old 1st April 2014, 07:16 AM   #10
artosalo's Avatar
400 V for screen and anode voltage is fully OK.
Adjust the cathode current to some 50...55 mA/tube.
Finally started on my 6L6 amp. Need tube suggestions.Hide this!Advertise here!
6l6 tube amp troubleshooring progress speakerfritz Tubes / Valves 6 30th September 2010 10:33 PM
Williamson 6L6 Monoblocks (Finally) sorenj07 Tubes / Valves 20 18th May 2007 03:08 PM
Finally finished my first tube amp! Jeb-D. Tubes / Valves 34 1st June 2006 04:53 PM
6L6 Triode strapped amp suggestions bobhayes Tubes / Valves 8 28th September 2005 06:37 AM
rebuilding 6L6 amp ... suggestions? phonon Tubes / Valves 67 17th April 2003 12:27 AM
Copyright ©1999-2017 diyAudio
