PP 2A3 Fixed Bias - Page 3 - diyAudio
Old 1st April 2014, 09:02 PM   #21
mr2racer's Avatar
Jim, Hammond doesn't make a power transformer with two center tapped secondaries. Neither does Edcor. I would have to buy two. And then the 2.5 volt 6 amp winding in the main transformer would be wasted. Arlyn at Heyboer can build the one pictured above for about $45. And it'll be about the size of a small choke. Closest Edcor could come would be $15.38 x 2 plus $15 dollars shipping. Same price.
Old 2nd April 2014, 12:14 AM   #22
MelB is offline MelB  Canada
You could buy two of these:
Invalid Request
Your B+ transformer will run cooler and it's cheaper.
Also..the are small.
Just throwing out some ideas.
Hrmmm..hope the link works. If not...search digikey for 166M2 Hammond.
EL84 fixed bias PP Triode DrewP Tubes / Valves 23 24th November 2013 08:17 PM
6l6gb PP w/fixed bias? 807tubenut Tubes / Valves 9 17th October 2010 10:02 PM
Finding bias point in PP fixed bias beamnet Tubes / Valves 14 7th December 2008 01:25 PM
EL34 pp "fixed" bias is wandering OzMikeH Tubes / Valves 14 6th May 2008 02:17 PM
Fixed bias PP questions SHiFTY Tubes / Valves 1 10th July 2004 12:42 PM
Copyright 1999-2017 diyAudio
