diyAudio (
-   Tubes / Valves (
-   -   Valve heater question (
brucetassin 25th March 2014 10:53 PM
1 Attachment(s)
I'm build an MM phono pre-amp. It has alot of 60 hz hum.
The heaters are wired as shown in the diag. Is this part
of the noise problem?
piano3 25th March 2014 11:14 PM
I always make sure my heaters are ground referenced, otherwise the heater to cathode potential is not defined. I also probably wouldn't share the supply between rectifier and phono valves. AC is ok if your wiring is really good.
vinylkid58 25th March 2014 11:16 PM
Originally Posted by brucetassin (
Is this part of the noise problem?
Probably "most" of your noise problem.;) Separate windings to heat the rectifier and DC for the signal tubes is pretty standard for a preamp AFAIK.
scott17 26th March 2014 01:10 AM
I've used the 6CA4 before with filament voltage shared between the rectifier and other tubes as you show, with no hum, although not with a phono preamp.
You should try ground referencing or elevating the heaters as shown here:
The Valve Wizard
That may resolve your problem.
By the way, I used to live in Lawrenceville and have been to Loganville many times.
Eli Duttman 26th March 2014 02:05 AM
It is possible to have AC heating in a phono section, but the challenge is DAUNTING. The use of tubes with hum bucking, spiral wound heaters, is mandatory and, as has been mentioned, the heater supply must be biased off B+. Suitable tubes are the 6EU7 and the 7025. In current production, the Sovtek 12AX7LPS is a genuine 7025 equivalent.
Constructing a regulated 12 VDC supply for the phono section 'X7 heaters is easy enough. A "Rat Shack" 273-1366 filament trafo, a MBR20100CT twin Schottky diode, a big 25 WVDC 'lytic, and a 7812 3 terminal regulator are what you need.
BTW, regulating phono section B+ is a good idea. The little TO92 case LR8 is great for the job. Use 1 LR8 in each channel.
painted 26th March 2014 11:03 AM
Another reason for hum might arrive from the grounding regime used.
DF96 26th March 2014 11:21 AM
If the valves share a heater winding then the rectifier must be first on the chain, not last as you show it. This reduces the AC current around the first stage. Use thick wire to the rectifier, then thinner wire from there so you can twist it more tightly.
You must have a DC reference for the heaters; what voltage it is is less important than the fact that it exists.
Show us a picture. AC heater wiring is one of the few areas of audio where a picture tells us more than a circuit diagram.
brucetassin 26th March 2014 01:55 PM
Thanks all for your most valuable help.
I can see that I'm going to have to
rethink my approach to this project.
Triodethom 26th March 2014 03:47 PM
For phono I prefer dc heaters raised about 45volt above ground . This works based on RCA, and others data from the 1930s . At the time it was ac and raised voltage. I have seen an unused bias tap as a reference voltage be very quite . Care must be taken with heaters since the signal voltage is so vey small .
artosalo 26th March 2014 04:15 PM
Make a voltage doupler circuit from 6,3 VAC to 6,3 VDC with suitable filtering.
Resources saved on this page: MySQL 18.75%
