Old 22nd March 2014, 07:50 PM   #1
Default PSU for 6N6P
Hello,
I am developing a simple cathode follower with 6N6P tubes.
I would like to create a stable and low noise PSU for the anodics, which should supply about 70mA in total, with a not very high budget.
I designed a simple but functional schematic, do you think there something I could do better?
Old 22nd March 2014, 08:42 PM   #2
maton00 is offline maton00  Mexico
maton00's Avatar
Send a message via MSN to maton00
you could try lowering the HV with some 50 to 100 volts with a resistor and a Cap, before the regulating circuit.
It will also reduce the ripple = noise.
Old 23rd March 2014, 01:20 AM   #3
diyAudio Senior Member
fdegrove's Avatar
Where does this 70mA come from?
Ciao,
Frank
Old 23rd March 2014, 08:58 AM   #4
Thanks Maton00 for the suggestion. I was actually thinking I could use a RL//C network before the regulator instead of a R//C, so I could lower down th HV and filter the ripple at the same time. I could dimension the wire I use to build the L, in order to get the 1KOhm series resistance I need to lower down the HW with 70V.
Old 23rd March 2014, 09:03 AM   #5
Ciao,
Ciao Frank ,
70mA is a conservative evaluation of the load current.
I am planning to power up two tubes, each one biased at 20-22mA, so the total DC current should be 40-45mA.
Old 23rd March 2014, 11:08 AM   #6
artosalo's Avatar
If C2 in your schematic is really 1660 F, it is a total overkill.
After Q1 the ripple is already gone. Some 47...100 F would be quite sensible.
Old 23rd March 2014, 08:26 PM   #7
maton00's Avatar
You could do something like this and it will also reduce a lot the ripple
Old 23rd March 2014, 11:35 PM   #8
Thank you a lot for your suggestion guys. I come from a decent experience into discrete-components electronic design but this is my first design of tube-related stuff so your suggestions are really precious!! Luckily we have massives electronic labs at work so I have the opportunity to try and compare more configurations
I will try the last circuit using a 4H inductor, then I'll post the measurements from the scope.
Old 24th March 2014, 08:35 PM   #9
...dont forget a low value resistor on the emitter..it may help..
6N6P vs. 6N6P-I sparkle Tubes / Valves 60 13th April 2013 02:15 AM
Plate loaded 6N6P over SRPP 6N6P any day of the week... Bas Horneman Tubes / Valves 14 26th February 2011 04:43 AM
6N6P in an Aikido? Original Burnedfingers Tubes / Valves 29 20th January 2009 08:14 PM
6n6p amp timothyldodd Tubes / Valves 2 2nd October 2007 12:48 AM
Help with 6N6p dsavitsk Tubes / Valves 10 29th March 2007 09:34 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
