diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   pc mount el34 socket (http://www.diyaudio.com/forums/tubes-valves/25327-pc-mount-el34-socket.html)
kevin gilmore 4th January 2004 01:37 PM
Does anyone know the diameter of the pins for a
sk8 pc mount octal tube socket. And the pin 1 to pin 5
distance??
fdegrove 4th January 2004 03:42 PM
Pin diameter is 2.36mm (0.093").
Measured at the top or bottom of the socket?
The bottom may vary a little according to manufacturing tolerance.
Pin circle diameter is 17.45mm (0.687"), pin spacing is 45 degrees, alignment method 7.8mm (0.307") dia, splined center spigot.
Aliases:Octal, A08, A8, B8‑21, I.O. (International Octal), K, O, SK8
Cheers,;)
kevin gilmore 4th January 2004 05:59 PM
this socket??
http://www.partsexpress.com/pe/showd...=1199&CATID=42
I can believe the .093 but the .687 diameter seems
a bit small...
fdegrove 4th January 2004 06:39 PM
the .687 diameter seems a bit small...
That's because it's measured at the top of the socket.
If I had a PCB mount octal I'd measure it for you...
It should be slightly less than an inch but I suppose you need the exact figure fore your PCB design...
Anyone?
Cheers,;)
Copyright 1999-2017 diyAudio
