OPT secondary ground, stacked supplies - diyAudio
Old 17th March 2014, 04:40 PM   #1
kaputt is offline kaputt  Germany
Default OPT secondary ground, stacked supplies
Hi everyone!
Looking at several dc-coupled circuits with stacked supplies I found the output transformer secondaries to be either floating or referenced to input ground.
I'd say it makes sense to connect the secondary to input ground because connected to output GND (input B+) you would have massive DC on the output.
I am wondering if the connection of the transformer to two different supplies causes any problems. Maybe my question is a bit mushy but I am struggling with the concept...
Thanks for any help.
Old 17th March 2014, 06:20 PM   #2
Vinylsavor's Avatar
Hi!
Connect it to signal (input) ground. If you connect it to a supply you'd get zapped whenever you touch the speaker terminals, this would be dangerous.
Thomas
http://vinylsavor.blogspot.com/
6SN7-6V6x2 DC coupled 2 stage with stacked supplies homeskillet Tubes / Valves 34 29th September 2013 01:21 AM
Use only half of OPT secondary? dovla Tubes / Valves 2 14th January 2013 03:08 PM
cathode bypass on opt secondary alexg Tubes / Valves 4 2nd August 2011 01:54 PM
To ground or not to ground the OPT secondary, that is the question tomchr Tubes / Valves 20 7th May 2011 03:04 AM
Question about stacked pawer supplies sesquialtera Tubes / Valves 16 13th July 2010 07:03 PM
Copyright 1999-2017 diyAudio
