Yet another question about cathode bias (led+pnp) - diyAudio
Old 15th March 2014, 12:26 AM   #1
00940 is offline 00940  Belgium
Default Yet another question about cathode bias (led+pnp)
Any reasons not to use the following to bias the tube ? Besides complexity and cost of course, which is rather marginal compared to the rest of the amp.
Ben.
Old 15th March 2014, 05:14 AM   #2
DUG is online now DUG  Canada
Three diode drops and an LED with a current source in parallel with two of the diode drops.
I would like to see the V-I curve for that combination.
Would it be linear?
Does it compensate for tube non-linearity?
Interesting.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 15th March 2014, 08:54 AM   #3
needsp is offline needsp  United Kingdom
Hi
I bias my 300B driver stage like this. It sounds excellent
Paul N
Old 15th March 2014, 09:24 AM   #4
@needsp: yes, I've seen similar schemes. The idea was to get it but in a two-terminals fashion.
Ben.
Old 15th March 2014, 01:33 PM   #5
Would it be linear?
It's only sims but it seems like less is more.
edit: using a ccs in the simple version brings a very marginal gain.
Ben.
Old 15th March 2014, 02:15 PM   #6
Better than I expected.
Thank you.
Old 16th March 2014, 01:34 PM   #7
dirkwright's Avatar
There's a Walt Jung article about various different CCS. Have you read it?
Old 16th March 2014, 02:15 PM   #8
Yes, I did. But aren't we looking for constant voltage here ? I don't exactly understand what I should look at in his article.
Ben.
Old 16th March 2014, 03:13 PM   #9
dirkwright's Avatar
Perhaps you don't realize that a constant current through a constant resistance produces a constant voltage?
Otherwise, why not use a shunt type voltage regulator like a TL431? (it appears that you are trying to make something like that now)
Old 16th March 2014, 04:51 PM   #10
I do realize that... problem is that we don't have constant current. We need constant voltage with variations of +/-10ma, centered at 20ma.
A tl431 would indeed work perfectly. It's also a lot more complex (internally that is). But some have raised concerns about noise when using a tl431 for bias.
Ben.
LED cathode bias noise issue chip647 Tubes / Valves 8 22nd January 2013 09:02 PM
Switched to LED bias on 6SN7 cathode - how do I calculate current? cjkpkg Tubes / Valves 13 21st December 2010 02:01 AM
Ping Sy: LED for Cathode Bias arnoldc Tubes / Valves 177 19th December 2010 04:46 PM
LED cathode bias - how to pick LED? sharpi31 Tubes / Valves 32 9th November 2010 09:55 AM
Copyright ©1999-2017 diyAudio
