Interstage Transformer for Experimentation : Hammond 560L - diyAudio
Old 3rd January 2004, 01:41 PM   #1
Default Interstage Transformer for Experimentation : Hammond 560L
Iím working on an experimental driver stage, and I donít want to lay out the cash for really nice coupling transformers.
I found to transformers that cost about $50: the broadcast-quality Hammond 560L (http://www.hammondmfg.com/560.htm) and the Lundahl LL1544a (http://www.lundahl.se/pdfs/datash/1544a.pdf). However, Iím a bit confused by the ratings.
The Hammond 560L is rated Maximum power level 0 dbm. The Lundahl 560L is rated 22dBU. I need 10V peak-to-peak at the output of this transformer at 300 Ohms (therefore the input will be around 40V peak-to-peak). Output power = (10^2)/300 = 333mW.
So will either of these transformers work?
Old 3rd January 2004, 11:09 PM   #2
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Yer what?
0dBm = 1mW into 600R. 0dBu = 775mV(RMS), which is the same voltage, but doesn't specify an impedance.
The short answer is, no, those transformers won't work. The Lundahl is specified for a high impedance load (allowing the high dBu rating). What on earth imposes a 300R load?
PS 10Vpk-pk = 41.66mW across 300R
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 3rd January 2004, 11:11 PM   #3
The input impedance of a big MOSFET of a Zen amp.
Old 3rd January 2004, 11:31 PM   #4
EC8010's Avatar
Default Oh dear...
Power MOSFETs have huge input capacitance. Transformers hate shunt capacitance.
Old 3rd January 2004, 11:44 PM   #5
diyAudio Senior Member
fdegrove's Avatar
They do....Deep, deep sigh...
Considering a sabatical year..............
The BS I see....
Guess eveyone's a qualifried enginebeer nowadayys???
Lord...
Pfffffffffft....
Frank
Old 4th January 2004, 12:17 AM   #6
grataku is offline grataku  United States
Give the guy a break, driving a mosfet with an interstage is not totally unheard of:
http://www.wdehaan.demon.nl/5687_2.html
Old 4th January 2004, 12:22 AM   #7
fdegrove's Avatar
Think I don't know that?
Come'on...
Clevor Trevor's smarter than that P. What drives C? C!
Frank
Old 4th January 2004, 03:12 AM   #8
Looking at the Lundahl LL1544a datasheet, it is rated for 10 kOhm on the primary and 600 Ohms on the secondary (using 4:1 connection).
This seems like the transformer was designed to drive low impedances with the secondary. Using a triode on the primary (10 kOhm), the secondary should be able to drive the input of a Zen.
Iíve messed with the Zen design a bit Ė changed it to source follower configuration Ė and raised the input impedance. However, the gate capacitance issue still exists.
The gate capacitance of the MOSFET is within the specs given on the datasheet (470pF using the 1:1 connection ratio). The 4:1 connection ratio should allow for much more capacitance.
Old 4th January 2004, 03:36 AM   #9
fdegrove's Avatar
When people start talking SS lingo I'm at a loss, just second guessing what they mean...
I can only suppose the same is true the other way around....Errr, I secretely hope so...
Also, I do get the impression SS'anders have a tendency to complicate where pedestrian simplicity could do just the same?
Frank
Old 4th January 2004, 12:56 PM   #10
Default This should be simple enough ...
Here's what I'm talking about.
http://www.diyaudio.com/forums/showt...655#post294655
interstage transformer effindi Tubes / Valves 8 10th November 2009 12:51 PM
Interstage transformer for PI. jane Tubes / Valves 4 31st December 2005 06:04 PM
Interstage transformer as OPT? needtubes Tubes / Valves 10 14th March 2005 10:46 PM
Interstage Transformer Nomenclature TerribleT Tubes / Valves 20 16th January 2005 09:04 PM
Hammond 850Q Interstage? Joel Tubes / Valves 10 31st October 2002 08:43 PM
Copyright ©1999-2017 diyAudio
