Disappointing results from RH84 - Page 2 - diyAudio
Old 3rd March 2014, 06:56 AM   #11
jazbo8's Avatar
Originally Posted by tomchr View Post
It shouldn't be a problem to bypass the cathode resistor on the driver with a cap. That's what I do in my Novar Spud.
~Tom
When using a triode as the driver for the RH amplifiers, the cathode is left un-bypassed to increase the driver's plate resistance, this is one of the design features specified by Mr. Kitic.
Old 3rd March 2014, 10:17 PM   #12
2bamp is offline 2bamp  Canada
I thought that the intended use of the amp was with an mp3 player on the input. Oh well...
The voltages were measured through a Vector socket on top of the chassis. I will have to remeasure, as they don't quite add up. 340v is a bit strong on the power tubes, so I will have to add some sand.
I will try adding a small cathode bypass cap. If that doesn't do it, I will have to add another triode stage. I am sure a couple of 6C4 could fit in my chassis with a pot. A gain of 2 would likely be all I need. Hopefully it doesn't come to that.
Old 3rd March 2014, 10:22 PM   #13
tomchr is offline tomchr  Canada
tomchr's Avatar
It's Schade Feedback. There's nothing magic about it... I can't comment on AK's design choices, only say that it works well either way.
~Tom
Modulus-86: 40W/8Ω @ 0.000061% THD. HP-1: 3W/20Ω, 450mW/300Ω @ 0.000032% THD. DG300B and Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 3rd March 2014, 10:26 PM   #14
Sodacose's Avatar
2bamp-
If you think it's definitely the mp3 player output, you could give this nifty little trick a shot:
Antique Radio Forums • View topic - Passive Amplifier for your iPod 2 radio jack
I've always wanted to try it, but I haven't really had a need (perhaps when I finish my RH84 build...)
Part in question:
RadioShack Audio Output Transformer : Transformers | RadioShack.com
$2.99 a pop.
WTF Amps || /r/diytubes/
Old 4th March 2014, 02:38 AM   #15
Wow, great reading there. Looks like it is a matter of an impedance mismatch.
I am going to have to try a CD player as my source. I bet I have some suitable little transformers in my parts collection to make the matching unit. I will post up my results. Thanks for the idea.
Old 4th March 2014, 03:14 AM   #16
Sodacose's Avatar
Hopefully you were right about the lack of oomph from the driver. Would make sense that it's just not seeing enough V's from a headphone out. A 2V out from a CD player (or a mp3 player with that little transformer trick) might be all you need. Will be interested to hear results as I've just ordered some Transcendar iron for my build...
Old 4th March 2014, 03:57 AM   #17
jazbo8's Avatar
~Tom
I know what you are saying, I was merely pointing out that it was a key design choice on the RH amplifiers - it was left out on purpose.
Old 4th March 2014, 08:17 AM   #18
Shoog's Avatar
Indeed - its fairly important not to bypass the driver cathode.
Shoog
Old 4th March 2014, 11:32 PM   #19
I did some A/B testing with my consoles that use similar tubes. I can honestly say that I am happy with the RH84 as built. I just needed to listen more carefully.
It doesn't have quite as much power, but the sound quality much better. I won't bore you with "audiophile speak," but the frequency response and voicing are on a whole different level. The improved design built with NOS PIO caps instead of ceramic probably has a lot to do with it. My solution to the reduced power: move the amplifier to a smaller room.
For my next build, I am going to try making an integrated amp optimized for the lower line level of my digital sources. I am thinking of a single triode stage on the front end into a volume pot. I have lots of TV tubes, so perhaps a 6SN7, 6CG7 or a pair of 6C4.
Anybody done this already? I have scoured the interwebz, but haven't found any examples.
Old 4th March 2014, 11:53 PM   #20
aardvarkash10's Avatar
i'd be more inclined to put a 1:2 or transformer in the input. Two advantages - it would come close to matching your digital input voltages to CD line voltage, so less messing for different sources, and it would provide separation of ground loops
"It may not be easy for some to not hear differences, even if they are not there." - Vacuphile,
Disappointing stadium sound Cal Weldon PA Systems 46 10th December 2011 11:07 PM
Disappointing CD's.... mpmarino Music 153 7th May 2009 03:23 PM
OPA549 disappointing la9 Chip Amps 19 21st February 2006 09:34 PM
Adire DPL12, very disappointing? Otter Subwoofers 30 6th February 2005 03:36 AM
Copyright 1999-2017 diyAudio
