ST Triodes? ST Triodes? - Page 2 - diyAudio
ST Triodes?
ST Triodes?
Old 26th February 2014, 06:25 PM   #11
sporc is offline sporc  United States
Originally Posted by euro21 View Post
Why primarily IDH triodes?
Direct heating tube's tone -IMHO- is far better (26, 10Y/VT25, 801/VT62, 2A3...).
These are all ST tubes. :-)
But....globe version of these tubes even better.
All NOS ST DHT's are over $20 as are current production tubes like the 2a3.
I picked up 50 NOS 1626 for under $2 each a few months ago on eBay.
Old 26th February 2014, 06:57 PM   #12
New production Tung Sol 6l6G can be had for around $25.
Old 26th February 2014, 07:14 PM   #13
TheGimp is offline TheGimp  United States
TheGimp's Avatar
1626 is specified as a class C tube, and the graphs don't look very linear.
Have you had a chance to try them, and if so how do they sound?
Old 26th February 2014, 07:43 PM   #14
It's a pleasant sounding tube and a big improvement over the chipamp in my office which it replaced. That being said, you won't mistake this tube amp for a well designed DHT amp. I copied the original darling by Danielak, a well documented design.
Old 26th February 2014, 11:51 PM   #15
needtubes is offline needtubes  United States
I am familiar with the 1626, but didn't list it before since the mu is a little low for my needs.
On a completely different note... What does one mean by 'the graphs don't look very linear'? I know that 'linear' usually means the distortion spectrum falls so that 2nd, 3rd, 4th, etc. harmonics essentially look like a straight line. But, how does one see that from the datasheet?
Old 27th February 2014, 08:45 AM   #16
Vincent77 is offline Vincent77  Europe
Vincent77's Avatar
You can see in the Vg -> Va/Ia graph if the distance between the curves doesn't change much, if at higher current the curves are almost straight and they remain relatively parallel (they don't fan out much).
You can also look at the Va -> Vg/Ia curves : you should use the tube within the linear part of this curve.
You can take a look at a 300B as an example of linear device, and at, say, a 12AT7 for a less linear one.
Old 27th February 2014, 11:57 AM   #17
TheGimp's Avatar
Here is an extreme case of a triode with poor linearity. It was specifically designed to have remote cutoff characteristics by varying the grid turn spacing to make the grid turns less dense at the ends and more dense in the center.
The 6386 is a remote cutoff triode.
http://www.mif.pg.gda.pl/homepages/f...142/6/6386.pdf
It is possible to calculate the harmonic from measurements taken from the graph.
Old 27th February 2014, 05:08 PM   #18
Ah. That clears things up nicely. Thanks!
ST Triodes?Hide this!Advertise here!
What are your opinions of the ST-70 and St-120 ElCid79 Tubes / Valves 51 10th March 2015 10:48 AM
my 1'st time changing an xstr, and my 1'st post here :) Jave Solid State 12 2nd July 2011 10:58 PM
St 35 or St 70? scetoaux Tubes / Valves 13 19th February 2011 05:18 PM
College-proofing an ST-70 (aka autobias+ST-70) antiquekid3 Tubes / Valves 15 13th June 2010 03:37 AM
Copyright ©1999-2017 diyAudio
