Heathkit AA-151 troubles - diyAudio
Old 22nd February 2014, 07:56 PM   #1
Default Heathkit AA-151 troubles
I've recently recapped an aa-151 and replaced all resistors that were measuring out of tolerance. I've also replaced all the tubes. A little background of how this project all started though.
I inherited this amp and soon after noticed the el84's red plating. So a bit of googling educated me on what was happening. I wanted this amp up and running and also wanted to learn more about tube amps without having to take it to a repair shop so I took on the task of replacing the coupling caps myself. Soon after that I've since updated everything that needed replacing as mentioned above. The power caps were replaced with a 50/50 and a 30/30 JJ brand. All original caps (minus any ceramic) were replaced with CDE brand film, resistors are carbon film. The unit hums minimally and sounds good, however the main question i still need help with is the fact that I can't listen to it for more than 5 minutes without getting a headache/fatigue/sore ears. It's like there's some inaudible high frequencies being pushed but I cant say for sure as I don't have a scope or know what to look for. My ears are telling me something's wrong though. I've heard of maybe looking into 'bypassing the power caps' with smaller film ones but fail to understand what this would do to effect RF frequencies. Could it be any of the old ceramic caps in the tone section or any of the other carbon comp resistors that could be causing this?
any thoughts much appreciated....thanks!
Old 23rd February 2014, 07:50 PM   #2
Oscope would really help. Multimeter won't show high frequencies.
Old 23rd February 2014, 08:08 PM   #3
I'm wondering if it's at all worth it to rig a bucking transformer for it to lower my wall voltage from ~125 average to 117. Overall the entire amp is running hotter than normal and filament voltages are up to 6.6ish. All other voltages are proportionally higher than the schematic. I've had to change out the 100ohm cathode resistor for the el84's to be a 200ohm instead. I've been told that I should have kept the 100 ohm in and address high voltages with chokes, additional power resistors upstream, etc. I just want to keep the unit as stock as possible as well as have a solution somewhat within my skill level. The schematic says 117v operation and i'm wondering if the addition of 7-8 volts is really causing that much of a problem i.e. crossover distortion, etc. (which is probably what it is). Also wondering what the average tech would do (in my area it's like $50 just to look at anything regardless of any work done).
Old 23rd February 2014, 10:27 PM   #4
rmyauck is offline rmyauck  Canada
You can adjust too high filament voltages with resistors. Check voltages then under load. You have a 310-0-310 PS trans and the Dynaco ST-35 with a SS rectifier instead of a tube uses a 330-330 so your B+ wouldn't be any higher than in that amp.
Both amps are hard on output tubes, so going to a form of fixed bias is the best solution.
The EFB fixed bias is the cheapest and actually better (sonically due to it's design) than regular fixed bias which has voltage supplied by a separate transformer supplying low voltage. You can do that also by buying the small trans, a diode bridge and a few resistors and pots.
It's easy to wire up and runs off the B+ to the output transformers.
New Modifications for the Dynaco SCA35 and ST-35
Dave's Lab
Old 23rd February 2014, 10:55 PM   #5
Where are you at?
Old 23rd February 2014, 10:56 PM   #6
Ottawa Canada
Old 24th February 2014, 01:42 AM   #7
To keep it simple then try one 200-240 ohm resistor (200 ohms will be close to stock and a little bigger of course will reduce mA) with the cathode capacitor (so you will need a second one) per pair of output tubes as used in each channel. Look at the Eico HF-81 schematic. The Eico HF-81 used 165 ohms per pair of output tubes, but used a smaller PS trans. You will only need matched pairs per channel of EL84/6BQ5 tubes then.
Also do the bucking transformer mod with about a 5A transformer. A 12V one will get you just above 110V which will be great. You may need to make a 6V version for use when the line voltage goes down.
Still check your loaded filament voltages as you can guess too high is bad.
The Russian EV EB NOS output tubes will probably be the only new tubes to survive for a while verse other new production tubes. The EFB fixed bias or regular fixed bias would allow you to run other new production tubes like the JJ, New Sensor (EH, GL, or Tungsol) or the Psvane from China plus make the Russian NOS last longer.
As for the fatigue issue make sure you have the feedback wires at the speaker terminals hooked up and correctly. Check all the caps and resistors on that part of the circuit are okay also.
I have the same amp with no fatigue issues, but I'm in MB so can't help.
Old 25th February 2014, 07:10 AM   #8
multi is offline multi  Australia
Very Often you can find out if your amp is oscillating by tuning an Am radio close to the amp; if it is oscillating you will hear whistles as you tune the radio.
Phil
Old 25th February 2014, 12:43 PM   #9
I've tried this at the advice of others. Nothing seemed to be happening there. As I've been listening also now the amp has become noticeably quieter and less fatiguing. Another thing that came of this was that i noticed the right channel weaker than the left. I've yet to measure the dual gang pot but assume it's off. For now i've just turned the right channel up to match the left. Having one quieter than the other no doubt was adding to things being 'off'.
Also, the amp probably *is* running fine (albeit with higher than usual wall voltage), and i've been able to listen to it longer. It's just concerning me the actual health of the amp. Everything's been changed except the ceramic caps and any resistors that appear to be in spec, all new tubes (NOS except brand new JJ EL84), tone circuit untouched (treble pot is also measuring a bit high at 1.3meg) and all voltages are equal more or less across channels (just all proportionally higher due to 125v at wall) and of course the much higher 420v b+ due to raising the cathode resistor on EL84's.
Maybe this amp just doesn't do it for me? I've been impressed with it no doubt since coming from Solid State, but fear it to be to slow (tube rectified) or lacking the kind of clarity i'm use to. Also maybe something even simpler like a dynaco amp with a much simpler circuit (no tone controls) and one with healthier pots and all newer parts, etc.
Old 25th February 2014, 02:01 PM   #10
Make a Bucking Transformer, as whatever amp you have the Filament Voltages will be too high!
The caps (mainly coupling) are probably breaking in along with the new tubes and so the sound may even get better!
You can easily jumper out the tone controls with a switch to see that affect. There is a fellow in Canada (I think Montreal) that does basically that and afterwards people rave about the AA-151 as he rebuilds amps.
Changing the other components (the only thing left is the Output Transformers) that would have any affect is the Output Transformers, but new ones of the same construction, design etc. wouldn't make a bit of difference, as Age Doesn't change them.
You basically have the same circuit as the Dynaco SCA-35 an integrated , just different tubes.
The Eico HF-81 has the same circuit, but it's tone controls are better done, and it's power supply is good with no resistance added like the AA-151. You have better Output Transformers though, along with the ones on the Dynaco ST/SCA-35 (all the same) so have patience and hang in there!
You can do the diode mod which is adding SS diodes in series to pins #4 & 6 of the rectifier tube which will help it last as it takes some of the load off of it while keeping the slow warm up the the GZ34/5AR4 is famous for. It should improve the bass a little.
Then you can experiment further by removing the tube and jumpering in SS diodes. Use the newer faster & quieter UF4007 for a few cents more all mentioned over the older IN4007.
You can also buy aftermarket plug in tube SS rect. subs. Google. Copper ones.
The mod shown in the diagram uses unused pins on the rectifier tube to mount the SS diodes. Pay attention to the polarity.
The mod also helps the rectifier tube last when you have a power failure where it flashes off and on which someone can accidentally do with your amp.
Besides having nice iron the AA-151 has another plus in that it's P2P wired and has lot's of room to work on it.tuberectifier-diodemod.jpg
ReCap- Heathkit AA-151 Help stevegale Tubes / Valves 1 27th October 2013 09:57 PM
6bq5 tubes in a Heathkit AA-151 kent ashton Tubes / Valves 3 19th June 2013 03:16 PM
Need Help for Improving HEATHKIT AA 151 MyKPJ Tubes / Valves 0 16th December 2010 06:33 AM
Modifying Heathkit AA 151 zxx123 Tubes / Valves 11 24th February 2009 06:49 PM
Heathkit AA-151 for starting my first DIY build??? bbaker6212 Tubes / Valves 1 28th August 2002 12:27 AM
Copyright 1999-2017 diyAudio
