6n6p tube buffer - diyAudio
Old 21st February 2014, 09:47 PM   #1
Trileru is offline Trileru  Romania
Default 6n6p tube buffer
Hello.
I have an AK4396 DAC with an opa827 on the output stage.
I've been thinking for some time now of making a tube buffer, and I happen to have a few 6n6p tubes around.
I've drafted a cathode follower that sims good but I'm wondering what else could I do so I could improve the design?
At the moment I made it so it connects to the opamp output. Is there any advantage to bypass the opamp and connect the differential output to the buffer? I don't know how to adapt the schematic for that, sadly.
Old 22nd February 2014, 06:47 AM   #2
How about Broskie Cathode Follower? Or, in the same article you can find by google, the Unbalancer?
Old 22nd February 2014, 08:36 AM   #3
Unbalancer looks real nice, but I'd like to do a point to point wiring. Need to study the PDF and online article some more.
Thanks!
Old 22nd February 2014, 10:48 AM   #4
Hi Trileru,
Do you have a schematic of the DAC output with the OPA827? Instead of just plugging in a buffer after the 827, which will have very little impact I think, we could look at the whole to make suggestions.
Cheers, Erik
my surname is indeed 'de Best': neither misspelling nor snobbism! Ask SY!
Old 22nd February 2014, 11:28 AM   #5
This is the schematic, I think it's for AK4393 but should be the same for AK4396 minus output stage I guess.
Old 23rd February 2014, 02:18 AM   #6
wa2ise is offline wa2ise  United States
wa2ise's Avatar
I would have connected the output coupling cap on the cathode. Any reason to connect it to the junction of R1, R2 and R4?
Old 23rd February 2014, 03:41 PM   #7
I decided to do that after reading:
The Valve Wizard -Cathode Follower
More exactly this phrase:
"The output coupling capacitor will also need to be a high-voltage type, and can be chosen based on whatever you happen to be plugging the cathode follower into. Adding a resistor (around 1k) in series with the output will ensure stability, although it is rarely a problem. The output signal could also be taken from the junction of Rb, Rl and Rg. The signal will be slightly attenuated, but stability is ensured since Rb is then in series with the output impedance."
I guess I could take the signal directly from K. Anyway, I'm thinking of doing the Unbalancer circuit if it happens that I do need the extra gain.
As it stands now, the output of the dac is about 2Vpp.
6N6P tube - focus on Zoran Tubes / Valves 26 14th January 2012 04:42 AM
Small tube amp based on 6N6P jema Tubes / Valves 4 3rd October 2011 08:57 PM
6n6p tube as output tube for small guitar amp moonbird Tubes / Valves 28 7th September 2011 05:28 AM
cathode follower tube buffer using 6n6p nightanole Tubes / Valves 30 30th March 2011 10:37 AM
Plate loaded 6N6P over SRPP 6N6P any day of the week... Bas Horneman Tubes / Valves 14 26th February 2011 05:43 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright ©1999-2015 diyAudio
