GU-50 triode - diyAudio
Old 21st February 2014, 02:59 PM   #1
tolip is offline tolip  Norway
Default GU-50 triode
I have some questions about using GU-50 in triode connection. I've heard that I should not exceed 400V by much. What disadvantages would using higher voltage cause? I'm asking because I have a spare transformer and few GU-50s that I would like to use to build an A class.
Old 21st February 2014, 03:13 PM   #2
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
tried a forum search ?
I think there might be several threads with info
sometimes we know very little, and sometimes we know too much
Old 21st February 2014, 05:25 PM   #3
Tried search and found several that mention 400V being reasonable but couldn't find an answer if 520V is still acceptable and what the disadvantages would be.
Old 21st February 2014, 06:19 PM   #4
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
I think Anatoliy aka Wavebourn is the right person to ask...
Old 21st February 2014, 06:58 PM   #5
could thermal run away be the issue with higher voltage ?
or voltage is also relative ... ?
did you say classA ?
I suppose that means SE ?
don't know if anyone use it in SE ?
but in classA, is voltage not lower than AB ?
Old 21st February 2014, 07:25 PM   #6
cathode bias ?
Old 21st February 2014, 07:35 PM   #7
Class A push-pull.
Old 21st February 2014, 07:39 PM   #8
AJT is offline AJT  Philippines
AJT's Avatar
yes, he made a pp amp with 800 volts plate, look for the Pyramid amps.....Pyramid-IX monoblock, 200W from 4x GU-50
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 21st February 2014, 07:58 PM   #9
Yep, but it was in pentode mode.
Old 21st February 2014, 08:49 PM   #10
JZatopa is offline JZatopa  United States
wavebourn is the GU-50 expert, if he doesn't chime in here you may want to PM him. You can also find more info at his site.
I was considering building a pair of pyramids myself but I don't have the time and money right now. Maybe if he releases some PCBs I will be able to find some extra time and money.
GU-50 in Single-Ended Triode Configuration - What bias points? quikie22 Tubes / Valves 87 30th January 2013 09:00 PM
GU-50, GM70 and KT88 nina Tubes / Valves 44 27th September 2012 05:14 PM
GU 50 monoblock gedd Tubes / Valves 8 21st October 2011 10:08 AM
GU 50 output modification beamnet Tubes / Valves 22 15th January 2010 03:02 PM
Use of 12j1l and gu-50 tubes gemby Tubes / Valves 6 26th October 2008 09:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
Copyright 1999-2015 diyAudio
