isolation test
isolation test
Old 20th February 2014, 11:33 AM   #1
pointy is offline pointy  United Kingdom
pointy's Avatar
Exclamation isolation test
Hi I have a power transformer that i wish to test for isolation but I do not have a neon test bulb. Could I put a transformer primary winding in place of the neon lamp and then test the secondary winding with a multimeter, would this be a good isolation test. I would be using a 25w tungsten lamp bulb as a current limiter for mains supply to the DC supply.
Old 20th February 2014, 11:38 AM   #2
M Gregg is offline M Gregg  England
Er No..
The whole point of insulation test is the level of current flow and at what voltage? As soon as you load the one side of insulation you drain the leakage so you get a volt drop. ie no power to drive the indicator.
You should use something like a megger insulation resistance tester.
M. Gregg
Old 20th February 2014, 11:41 AM   #3
Just for interest,
There is no such thing as an insulator...
Everything has leakage it just depends on voltage level..and at what voltage it will break down.
Ie even the air will conduct if the voltage is high enough (lightning)
So insulation value and voltage<<<insulator >>>not a very good conductor.. (up to a point)
NB there are recommended values under IEE.
http://electrical-engineering-portal...n-resistance-2
The above is just an example...so how would you be able to measure the actual value?
M. Gregg
Old 20th February 2014, 12:24 PM   #4
Just had a look for the IEE
BS7671 can't find the 17th just the 16th at the moment>>> a bit rushed....
...ah well.
M. Gregg
Old 20th February 2014, 12:32 PM   #5
TheGimp is offline TheGimp  United States
TheGimp's Avatar
What are you trying to measure?
The actual resistance between windings, and windings to core? (IR Test per the link M Gregg pointed to)
The breakdown voltage between windings, and from windings to core? (Hi-Pot test)
Or something else?
Old 20th February 2014, 12:44 PM   #6
pointy's Avatar
Steps to first power on.
Testing the Transformer Part 2.
Old 20th February 2014, 12:47 PM   #7
infinia is offline infinia  United States
infinia's Avatar
you said isolation
he said insulation
what are you trying to accomplish in the end?
isolation on a transformer IE inter-winding capacitance is tested with a impedance bridge or a capacitance voltage divider over a range of frequencies. using a known value capacitor in series with the unknown inter-winding , the value then can be determined with a little math.
insulation is done with a Hipot tester > most electric motor shops have one
Dielectric Withstanding Voltage Test it takes about 30 seconds to run
Hipot - Wikipedia, the free encyclopedia
Old 20th February 2014, 12:58 PM   #8
pointy's Avatar
Thank you M Gregg what I shall do is take it to my local electrical store where I am sure they will have a megger insulation resistance tester.
Old 20th February 2014, 01:08 PM   #9
infinia's Avatar
in the link > he's just doing a simple continuity check with 400Vdc and a neon bulb.
yes u can use a DC ammeter instead of the bulb
Old 20th February 2014, 01:28 PM   #10
NB never Megger any semiconductors..ie they should not be connected to the Tx under test.
Some tests you can do with a meter just to see.
Test continuity of each winding low resistance.
Test between each winding expect very high resistance. Ie no shorts between HT and heater or any winding to primary.
All windings to the core.
If this is OK then the Megger test.
M. Gregg
isolation testHide this!Advertise here!
Ultimate listening test ... test your ears and audio chain PMA Everything Else 378 21st November 2013 10:20 AM
Test Signal for max power test of Class D? eem2am Class D 19 27th August 2012 09:22 AM
Is there any test cd to test jitter using a scope ? gaetan8888 Digital Source 4 10th August 2007 09:24 AM
Isolation eeka chu Tubes / Valves 4 6th December 2004 06:53 PM
about isolation rulezzz Chip Amps 1 8th January 2004 05:36 PM
