Tubes suggestions for parafeed headphones amp ?
Hello,
I'm on the search for suitable tubes for a simple parafeed headphones amp.
What I've got:
- A 270Vdc/60ma regulated B+
- A 12.6Vdc or 15Vdc @1A supply.
- A pair of 10K-7K/300-32 transformers.
- A pair of ss CCS or gyrator, so anode voltage will be at about 200V.
I'm considering tubes with µ in between 25 and 40, lowish rp, medium power dissipation (at least 3w, more is better).
For now, I've been looking at ecl84/pcl84 (pentode section, triode strapped), at the 6ag7/6P9 (again, triode strapped), the el83/pl83 and the 6922 (sections in //).
Any obvious or less obvious tube I'm missing ?
Been there, done that 😉 I'm looking for something a bit different.
What I'm really looking at is a tube I can use this way:
I've built a parafeed headphone amp like this and it works well for 150 ohm headphones but if you want to drive 32 ohm ones, then I agree with artosalo; cathode follower or source follower as output stage. Using ccs as load for both stages should optimise performance.
Thanks needtubes ;-) I think the 6N6P will be my backup solution. I'm going to try the 6E5P first.
Btw, one has to be careful connecting the parafeed to the µ-follower point of a gyrator;
+: you indeed get a very low output impedance
-: to avoid a large low frequency bump, you'll end up needing a much bigger parafeed cap.
+: the tube is operating at almost constant current.
-: the power supply is not seeing a constant load anymore
Thanks Shoog, Vincent77, that's more in line with what I'm looking for.
I have built a parafeed spud. It takes E186F/ D3a / 6J9P and equivalents, *triode strapped*. In my opinion, these space-age, high transconductance pentodes sound much better than the usual double triodes.
Out of curiosity: did you compare the 6J9P to the more expensive western tubes ? How did it fare ?
Resurrecting this old thread as this amp is finished, finally using a pair of 6E5P.
The schematic is very simple, similar to the "torpedo" (it's using the same output transformers, 10k to 300-32 from edcor). Besides the different operating points, the only differences are a RC damping network to tame the rising very low frequencies and a lm2596 as regulator for the heaters.
It sounds good to me. The external transformer helps with noise.
Some (bad) pics attached.
