6H9c Idle Current.
6H9c Idle Current.
Old 16th February 2014, 02:18 PM   #1
kees52 is offline kees52  Netherlands
Default 6H9c Idle Current.
Hi There
I have seen much people who says, low idle current give tube more detail, others say put it in class A to get better sound.
What are your experience with idle current, I have a cascode mosfet on plate so I have a horizontal loadline, because of this distortion is low make tube sound hars/hard buit with a lot detail and deepness.
I did use a 6H9C, I have heart this are hars sounding tubes.
A penthode 6J9N in triode mode last time did make warmer sound, what I do like, this 6H9C do not, the 6H8C will do sound warmer, more what I like.
regards
kees
Old 16th February 2014, 03:16 PM   #2
azazello is offline azazello  Bulgaria
azazello's Avatar
Idle current about 2 ma /more current - big sound, IMO/
But I prefer 6SN7 with 8 - 10 ma /Loftin-White two stages with adjustable gain from 20 to....max/.
Projects: OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,... PPs 6005 Gen. Electric, EL34 Mullard, 6L6....
Old 16th February 2014, 03:33 PM   #3
I have now put it on 0.5 mA and it do sound nice, don,t forget I have a horizontal loadline, not a resistor loadline, this change things.
2 mA put 0.4 watt dissipation on tube when 200 volt on plate. I go try out what sound it delivers.
I have to use a high mu triode because of it is a mosfet hybride amplifier, it do the full voltageswing needed.
regards
kees
Old 16th February 2014, 04:01 PM   #4
A 6H9C on 2 mA is not so good, cahtode resistor is to low make just 1.45 v negative, resistor 680 ohm is needed for 2 mA.
I let it on 0.5 mA for a while, looks like it has more detail and deepness.
Still a penthode do better.
Old 22nd November 2014, 01:56 PM   #5
After a longer time I did look again on the current who has to be 2.3 mA but I did say about the cathode resistor make not enough negative (negatief needs -2 volts, input signal 1 volts max).
Solution is higher voltage, this tube likes high voltage, make it sing.
Old 22nd November 2014, 03:29 PM   #6
Palustris is offline Palustris  United States
Palustris's Avatar
From the plate curves it would appear that at Ip = 2mA you would have Ep = 160V and grid bias would be -16V. Your cathode resistor would have to be 8k ohms.
Old 22nd November 2014, 07:52 PM   #7
When I do this I get not 2 mA with 8 k ohm, I have included a measurement with plate voltage 260 volts, and 1 K ohm cathode resistor I get 2.04 mA.
When I do in sim 8 K ohm and 160 volts then i get no more then 0.227 mA that is quite low??, I did read somewhere these tubes need high voltage to sing properly.
Do I miss something here, don,t forget I do use cascode fets so loadline is horizontal, things change..
Now the amp plays with 260 volts plate voltage and 1 K ohm cathode resistor and I get 2.04 mA max is 2.04 volts on 1k resistor.
Or do I have bad tubes, she are in original box.
regards
kees
Old 22nd November 2014, 09:21 PM   #8
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
R4 should be on the grid, not the grid leak resistor!
Valves are very tollerent and do not need special component values.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 22nd November 2014, 09:36 PM   #9
This is drawn there I have did in final schematic in eagle corrected I did see, also is now 1k ohm.
I still do not get on why cathode resistor 8 Kohm and 2 mA and 160 volts? I do not get more then 0.227mA?, I have now 260 volts (plus minus) en have with 1 K ohm resistors 2.04 mA.
So what is problem?
thanks.
Old 23rd November 2014, 05:32 PM   #10
Palustris's Avatar
I would guess that you have a problem with the design of the CCS. Try breadboarding the circuit to test it.
6H9c Idle Current.Hide this!Advertise here!
MC2200 idle current native Solid State 2 19th March 2012 04:05 AM
Matching at idle current diy didi Solid State 2 31st January 2012 12:51 PM
cascoded gyrator loaded 6H9C to low idle. kees52 Tubes / Valves 11 29th December 2011 05:24 PM
help setting up idle current lensmanMk2 Solid State 31 11th March 2010 12:48 AM
SMPS Idle Current cm961 Parts 2 20th February 2004 06:56 AM
Copyright ©1999-2017 diyAudio
